12-29-2015, 05:36 PM | #1 |
4x4 Problems
I just picked up a 1977 Chevy K10 about a month ago and have just had the first significant about of snow fall. I went to get out of the driveway and onto the road and i had a hard time getting out even though i locked the front hubs and had it in 4hi and tried 4lo. When i looked just the right rear wheel had been spinning for traction. So it seemed like my 4x4 wasn't working. What could be the problem here? Is it working right and it just to much for the truck or is something wrong with my truck?
I am pretty sure the truck is all stock drive-train and sense it is a manual it should have the gear driven np205 transfer-case. |
12-29-2015, 05:42 PM | #2 |
Re: 4x4 Problems
77 should have a NP203 which is a full time transfer case. If you have locking hubs then perhaps someone put a part time kit into your truck in which case the shift pattern is COMPLETELY changed over the original shift pattern.
Either way to confirm what transfer case you have crawl under the truck and either take a picture or look for a round circle with 3 bolts in the middle of the case. If you don't have the round cover with 3 bolts its a 203. ** Edit ** Most 1/2 tons were equipped with automatic transmissions and mostly the 3/4s tons got the manual. Still sounds to me like something was swapped so again.. take a look underneath. |
12-29-2015, 06:28 PM | #3 |
Re: 4x4 Problems
This picture says it would be something else. (Picture from fourwheeler.com) Also i was told it was a K10 could be a K20. It has the 3 speed with a granny low.
12-29-2015, 06:55 PM | #4 |
Re: 4x4 Problems
Really need to post a pic or 2 from the sides and back. We can help ya identify it pretty easily.
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
12-29-2015, 08:10 PM | #5 |
Re: 4x4 Problems
It should be a 205 and the chart confirms it. I must say I never saw a manual with a 203. I wonder if the transfer case linkage is sticking somewhere. I have only had 203's but I did have one that the shifter was messed up and wouldn't activate the 4wd lock lever on the transfer. I had to unhook the linkage and move the lever manually. I don't know if a 205 works that way but I would play with the shifter and make sure the hubs are locked in. I would jack up each front wheel to be sure the hubs are locked first. Then see if the front drive shaft turns when you put it in drive and try to move. Goodluck.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
12-29-2015, 08:25 PM | #6 |
Re: 4x4 Problems
This is the truck and it does feel like it is shifting into the 4x4 gears so i will have to try and check the locking hubs.
12-30-2015, 12:16 AM | #7 |
Re: 4x4 Problems
I had a 75 with a 4 speed & 203. They are out there.
12-30-2015, 12:21 AM | #8 |
Re: 4x4 Problems
i saw a pickup and a K5 with a standard/203.
we need a picture of the transfer case not just the truck. are you sure the hubs werent locked and you unlocked them? maybe some cheap hubs with the markings worn off? |
12-30-2015, 12:22 AM | #9 |
Re: 4x4 Problems
lightly tap the wheel hubs(on the iron part) with a small hammer or wrench. Sometimes the wheel bearing grease is kinda old and sticky and wont let the hub engage.
12-30-2015, 03:45 AM | #10 |
Re: 4x4 Problems
With it on the ground and hubs unlocked, put it into 4wd and try to spin the front driveshaft. It shouldn't spin. If it spins, there is a problem in the case or with the linkage. Now, lock the hubs, put the transfer case into neutral and try to spin the front driveshaft. It shouldn't spin. if it spins, look to see if the front shafts are spinning. If they are, there is a problem in the hubs. If they are not spinning, there is a problem in the front differential.
This is, of course with an NP205. There is still the possibility you have an NP203, but we can't tell without seeing a picture of the case. |
12-30-2015, 09:40 AM | #11 |
Re: 4x4 Problems
Cool truck no the less!
12-30-2015, 10:26 AM | #12 |
Re: 4x4 Problems
Nonstop has some good troubleshooting steps no matter what transfer case you have. You need to find where your problem is.
1973 C20, 350/350 |
12-30-2015, 11:48 AM | #13 |
Re: 4x4 Problems
I had a similar problem with my 82. Of course I discovered the 4 x 4 wasn't working while attempting to pull a boat/trailer out of a little lake at the bottom of a steep ravine..... Got lucky, (thank God I have a limited slip diff).... and was able to get out in 2WD. Turns out one of my Warn hubs was not working properly. Even though I was turning the knob, the internals on one side were not engaging. I could be wrong, but seemed like if one side doesn't engage... the other side doesn't work either...? I bought a new set of Warn manual locking hubs, repacked the inner/outer wheel bearings, and never had a problem since.
12-30-2015, 05:50 PM | #14 | |
Re: 4x4 Problems
1973 C20, 350/350 |
12-30-2015, 08:31 PM | #15 |
Re: 4x4 Problems
From the picture, it looks like he has locking hubs. I realize that doesn't guarantee it's a 205 transfer case, but it does make it very very likely.
I like nonstop's advice a few posts ago. Lock the transfer and unlock the hubs, and see if you can spin the front driveshaft by hand. This will tell you if the transfer case is locking properly. Then unlock the transfer case (neutral), and lock the hubs, and try to spin the driveshaft again. This will tell you if the hubs and/or front diff. are locking properly.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
12-30-2015, 08:36 PM | #16 |
Moderator
Re: 4x4 Problems
Trucks didn't come with limited slip stock. Just Eaton G80 Gov Bomb lockers. In the last 40 years anything is possible tho.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
12-30-2015, 08:48 PM | #17 | |
Re: 4x4 Problems
From what I've read the G80 in the 14ff isn't too weak... I hope not as I'm planning on picking one up this weekend. Then again I don't have big tires.
1973 C20, 350/350 |
12-30-2015, 09:06 PM | #18 |
Moderator
Re: 4x4 Problems
I believe it was only in the rear.
Maybe I misread his post I thought he was getting the one wheel peel at the rear... Limited slip diffs are available for the Dana 44 so it's possible someone installed one. The G80 is reputed to be pretty fragile even in the 14bolt. Don't use LS additive in it just gear oil.
12-31-2015, 09:53 AM | #19 |
Re: 4x4 Problems
The Detroit Locker for GM 14 bolts is one of the cheapest ones to buy. I wouldn't screw around with any used one.
01-04-2016, 06:48 PM | #20 |
Re: 4x4 Problems
I did find out that i have a limited slip in the back and the hubs were full of water and mud so they couldn't lock into place.
01-04-2016, 07:17 PM | #21 |
Re: 4x4 Problems
That's not good. I hope they aren't too beat up from that, at least they're working now.
1973 C20, 350/350 |
01-04-2016, 07:18 PM | #22 | |
Moderator
Re: 4x4 Problems
1977 is probably still a Dana 44. How crunchy are the Timken tapered wheel bearings? Probably not great. Don't forget there's a Cartridge Needle Bearing inside the spindle that the stub end of the axle rides inside. If there's mud inside the hubs the bearings are probably not in useable condition. Once you're that far into it it's not much more work to replace the Axle Universals and the inner axle seals. Don't cheap out on the bearings, seals, and 5-760X U-Joints. Timken, Chicago Rawhide and, Spicer aren't much more than the cheapies and they are worlds apart in quality. It's enough work that you don't want to be doing it again in the next 5 years. You may need a Speedi-Sleeve if the stub and inner ends of the axle are grooved where the seal runs. Is it a GM-Eaton G80 locker or an actual aftermarket Limited Slip?
And please let us know if and how your repairs were successful. Last edited by hatzie; 01-05-2016 at 12:34 PM. |
01-05-2016, 11:24 AM | #23 |
Re: 4x4 Problems
Yup, you better go through those bearings. I lost a wheel bearing in my truck and I didn't notice it until it was way too late. I am even a mechanic and listen for any strange noises all the time and even maintain this truck more than all my other vehicles. I was amazed at how destroyed my spindle was and I didn't hear or feel a thing. They fail fast once mud gets in there.
01-09-2016, 10:27 AM | #24 |
Re: 4x4 Problems
I don't know what I have for axles so I took a picture of both axles to see if you guys would know which ones they are. This is a little off topic but I was wondering if anyone knows of a way to look up what my truck came with for options? Also I did end up finding out that the truck came with an automatic and was converted to a floor shift. I found this out when the steering column was replaced in my truck.
01-09-2016, 10:32 AM | #25 |
Re: 4x4 Problems
It wouldn't let me put them one the same post.
