Old 12-29-2015, 06:47 PM   #1
rgtrough
rgtrough's Avatar
New guy here "66 4x4 sort of
Hey guys, new to the forum but not forums. I just purchased a 1966 4X4 C10.
Yes I know. The first letter of my serial number is C not K. Thats ok the build appears to be done well. It is a 292 4 speed. This is a very solid truck. Cab, bed, frame, and driveline in very nice condition. My question for youall is about the transfer case. It only has hi (all the way up) and low (all the way back). Any idea what unit this is? Part or model numbers? Years in production?
any and all useful information is greatly appreciated.
peace Bud
1966 C10 4X4
1962 Impala Sport Coupe
1974 Corvette Coupe
1987 Suburban
rgtrough is offline   Reply With Quote
Old 12-29-2015, 07:41 PM   #2
RANDY COX
RANDY COX's Avatar
Re: New guy here "66 4x4 sort of
if it's original I think it's a Rockwell T-221 I'm sure the experts will chime in.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 12-29-2015, 07:45 PM   #3
RANDY COX
RANDY COX's Avatar
Oh BTW welcome to the site and we need to see pixs, cause we all lik'em.. My truck is a 64 on a 70 4x4 frame and running with a 292 and 4 spd to...
1964 BBC 402 4x4
Old 12-29-2015, 09:28 PM   #4
j.kirn
Pics of transfercase would help indentify it.
j.kirn is offline   Reply With Quote
Old 12-29-2015, 09:34 PM   #5
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
X2 on pictures! And welcome aboard!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 12-29-2015, 10:50 PM   #6
rgtrough
rgtrough's Avatar
Hey guys, thanks for the replies. I will be happy to post pictures as soon as I learn how. I don't have any photos of the truck on my computer yet.
peace Bud
1966 C10 4X4
1974 Corvette Coupe
1987 Suburban
Old 12-30-2015, 01:15 AM   #7
rgtrough
rgtrough's Avatar
Hey guys, Is the t221 a constant supply transfer case? Because the one I have is.
peace Bud
1966 C10 4X4
1974 Corvette Coupe
1987 Suburban
Old 12-30-2015, 01:47 AM   #8
'63GENIII
'63GENIII's Avatar
Welcome to the sickness! Not sure what you mean by "constant supply" but one identifying feature of the 221 is that the rear output is in line with the front output with the input shaft located above both of them. Most modern TCs have the rear output inline with the input shaft. Pics would be great when you get a chance to post!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 12-30-2015, 09:28 AM   #9
rgtrough
rgtrough's Avatar
By constant supply I mean the front driveshaft turns when ever the truck is moving. No four wheel high, four wheel low, two wheel high.
Old 12-30-2015, 09:30 AM   #10
rgtrough
rgtrough's Avatar
I will take some pictures today. That is if the sun ever comes up.
Old 12-30-2015, 09:41 PM   #11
rgtrough
rgtrough's Avatar
Old 12-30-2015, 09:43 PM   #12
rgtrough
rgtrough's Avatar
Old 12-30-2015, 09:59 PM   #13
Classic v6 GMC's
Classic v6 GMC's's Avatar
That is the Rockwell T-221
It should have 2 HI, 4 HI, N, 4 LO
Classic v6 GMC's is offline   Reply With Quote
Old 12-30-2015, 11:20 PM   #14
rgtrough
rgtrough's Avatar
Where is the shifter position for 2 wheel hi?
Old 12-30-2015, 11:32 PM   #15
Classic v6 GMC's
All the way forward I think.
Look at this thread post #7
http://67-72chevytrucks.com/vboard/s...d.php?t=454325
Old 12-30-2015, 11:49 PM   #16
rgtrough
rgtrough's Avatar
Thanks for the reply. The thread shows 2 Wheel Dr. all the way towards the dash. In this position when I disengage the clutch the driveshaft going to the front differential turns.
Old 12-31-2015, 12:06 AM   #17
Classic v6 GMC's
Can you find all 4 positions? Maybe someone else will chime in
Old 12-31-2015, 12:44 AM   #18
allchevy58
allchevy58's Avatar
Are your front hubs in the lock position?
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 12-31-2015, 12:50 AM   #19
rgtrough
rgtrough's Avatar
No
Old 12-31-2015, 12:54 AM   #20
rgtrough
rgtrough's Avatar
No only all the way forward (2 wd ?) neutral in the middle and all the way back (4 wd lo)?
Old 12-31-2015, 11:48 AM   #21
Classic v6 GMC's
Maybe you are in (4 wd hi)? not all the way forward?
Old 12-31-2015, 12:05 PM   #22
VonDog
VonDog's Avatar
This pic is of a 1960 Rockwell T221. I think they're the same. My front was turning too so I had to adjust the stick shift linkage to get it into 2wd
60 K20, eaton HO52, T221, SM420, Dana 44 closed
78 K20 Burb, 14 bolt, NP205, SM465, Dana 44 open
05 Dodge Ram 2500 5.9 Cummins 4x4
VonDog is offline   Reply With Quote
Old 12-31-2015, 02:10 PM   #23
rgtrough
rgtrough's Avatar
This pic is of a 1960 Rockwell T221. I think they're the same. My front was turning too so I had to adjust the stick shift linkage to get it into 2wd.
You both were right. This morning I jacked up all 4 corners and ran the truck in all 3 positions, with and without the front axles engaged. I had to use a pry bar to get 4 wd disengaged. Adjusted the linkage and now I have 4 distinct positions. I imagine I never got it to shift out of 4 hi after I tested it. This truck has sat in a garage for the last 7 years, only driven in nice weather.
Thanks to all who replied, you made troubleshooting this proble easier. Now on to the electrical system.
peace Bud
1966 C10 4X4
1974 Corvette Coupe
1987 Suburban
