Old 09-18-2003, 11:43 PM   #1
bigvinnie
bigvinnie's Avatar
smallblock 400 donor vehicles...??
Anyone know which vehicles came with this motor....?? Wanna keep an eye out for a good cheap rebuildable core...
thanks.
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 09-19-2003, 06:56 AM   #2
Woody
Early 70's Impala, Caprice, trucks....That is all I can think of.
Woody is offline   Reply With Quote
Old 09-19-2003, 07:28 AM   #3
JJR
JJR's Avatar
Hollander shows the following could have a 400 2bbl engine:
70-76 Big Chevys (Implala, Caprice, etc)
74-76 Monte Carlo
74 Chevelle
75-80 Trucks/Blazers/Vans (GMC's also)
78-80 Suburban
75-76 GMC Sprint
Your best bet will be the big Chevys. In the big Chevys look for station wagons. I had a friend back in college that got a 400 out of a station wagon and put it in his 73 rally sport Camaro and could roast his tires all day long.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 09-19-2003, 08:47 AM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
Back around 78/79 or so, I had a 74 Chevelle wagon as a dealer loaner. It had the 400 in it.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 09-19-2003, 02:21 PM   #5
bigvinnie
bigvinnie's Avatar
thanks for the info... I figured that the mid-70s boats would probably be a source, but wasn't aware that the trucks had em too....
Wasn't there a thread on how to identify a 400 recently...??? for some reason I don't have rights to use the search engine...
anyone else have this problem...???
72 Stepside Project
Old 09-19-2003, 02:35 PM   #6
tom hand
CCRider
tom hand's Avatar
Some 400's had two freeze plugs per side...some had 3 per side. The ones with 2 per side are more desirable...and get this, the 2 bolt mains are the better block because the four bolt mains were prone to crack where the outside bolt holes were drilled.
http://www.eecis.udel.edu/~dzug/92z28/406project.html
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 09-19-2003, 04:10 PM   #7
palallin
Search is disabled while Josh works on some bugs.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 09-19-2003, 11:45 PM   #8
72c10step
WHYBYNU when old will do?
72c10step's Avatar
Where can you get the Hollander book from? It sounds like a goldmine!
-72 Chevy C10 Stepside
-2002 Chevy Silverado 2500HD 4x4
-1984 Jeep CJ7
-1995 Polaris XCR600 Custom
-2003 Honda 300ex
72c10step is offline   Reply With Quote
