Old 12-30-2015, 10:30 AM   #1
RJC
1960 vent window
Been awhile since I have posted. Back to working on these trucks. I'm rebuilding my vent windows and needing helping removing glass assembly so I could replace weather stripping. I have done 67 windows and up but different from earlier model. I've taken tension spring off now trying to figure out removal from frame. Any help greatly appreciatedName:  1960 vent window 001.jpg
[ATTACH]1482355
RJC is offline   Reply With Quote
Old 12-30-2015, 11:24 AM   #2
jbgroby
jbgroby's Avatar
Re: 1960 vent window
you'll have to cut and remove the outer rubber to give you the clearance you need. Once done, you need to gently pry up the top of the frame to pivot the glass frame out.
jbgroby is offline   Reply With Quote
