Old 12-30-2015, 05:51 PM   #1
LockDoc
The Older Generation
LockDoc's Avatar
LSX adapters that Aruba1 mentioned in Ackattack's thread
I didn't want to muck up Ackattac's thread so here is a link to the e-Bay adapter plates that Aruba1 mentioned.
I just ordered 2 sets.
http://www.ebay.com/itm/131687298380...%3AMEBIDX%3AIT
It says 4 position but you would actually have 8 positions with the '67-'72 trucks because of the two sets of frame holes....
I had a little trouble finding them on e-Bay without a link.
LockDoc
Leon
Old 12-30-2015, 07:08 PM   #2
Aruba1
Re: LSX adapters that Aruba1 mentioned in Ackattack's thread
I had doubts in posting the link because I didn't want to get in trouble :-(. I also bought a pair because the price is too good to pass. Cheers.
Aruba1 is offline   Reply With Quote
Old 12-30-2015, 07:17 PM   #3
slotard
Those sure are cheap. I wish they would let you mount it a little back from stock though.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 12-30-2015, 07:41 PM   #4
clemsonteg
Any concern because they are so cheap? Inferior merl or bolts perhaps? It is certainly tempting
clemsonteg is offline   Reply With Quote
Old 12-30-2015, 08:10 PM   #5
aknovaman
They are affordable because of low overhead, little advertising and not a greedy bunch of stock holders that demand high profits or some fat cat sitting behind a desk.
They also make high quality accessory drive brackets.
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 12-30-2015, 09:47 PM   #6
Aruba1
I purchased a set from them (LSX to SBC location, non-adjustable) over a year ago and I believe I paid like $45.
I was very pleased with the product however on my adapters I had to make some very small modifications. The adapters bottomed out (D and P side) on the ridge of the block and if you don't grind the ridge by roughly 1/4" you will bent the adapters or break something else. I think one of the countersink bolts had to be shorted a little bit as it bottomed out. The other issue was related to just the Passenger side. I had to cut off 1/4" of the bottom of the motor mount so it would clear the boss (?) where the a/c bracket is suppose to go. These are very minor modifications and in my opinion the adapters are too under-priced.
Sorry for the broken english, lol.
Old 12-30-2015, 10:40 PM   #7
the ideaman
the ideaman's Avatar
I just bought a set for my '67, 525/376 swap.
the ideaman is offline   Reply With Quote
Old 12-31-2015, 12:44 PM   #8
LockDoc
LockDoc's Avatar
If you read the description it says:
Made in the USA from aerospace grade billet aluminum.
Includes: 2 adapter plates, 8 Stainless Steel FHSC bolts, and 6 flange bolts. I don't know what all that means but you can look it up....
If you enlarge the pictures you can also see the grade numbers on the head of the bolts.
LockDoc
Leon
Old 12-31-2015, 01:34 PM   #9
slotard
I've encountered bolts that are marked as Grade 8 that appeared to be made of Chinesium so markings aren't always enough.
I'd probably trust it though, motor mounts aren't that heavily stressed in most situations.
1973 C20, 350/350
Old 12-31-2015, 04:27 PM   #10
clemsonteg
LockDoc
Yeah I saw that. "Aerospace grade@ seems like fluff words that a seller would use push their product. I think aluminum and aluminum alloys typically Coke with a designation. I bout a set anyways. Good price and depending on how the hardware looks I could probably replace it and still be under $40. Thanks for sharing!
Old 12-31-2015, 05:25 PM   #11
slotard
I'd be surprised if the aluminum is anything other than 6061 T6, as it's by far the most common (and often referred to as "aerospace grade"). Should be adequate for this, it's as strong as mild steel. I'd be far more concerned about the bolts.
1973 C20, 350/350
Old 12-31-2015, 06:40 PM   #12
Aruba1
These kits are not for you. Please purchase kits that cost $125 or more so you can have a piece of mind that what you are getting is the best of the best of the best.
I used a set in my truck a year ago (same company), they torqued just fine, they look like your normal bolts, the quality was really good and they don't seem like they would disintegrate after a few years. Guess what, the countersink bolts also torqued fine.
Old 01-05-2016, 12:04 AM   #13
Aruba1
Just wanted to post some pictures of the motor mount that I got in the mail today (free shipping included 2 day delivery). Now I only need to get a pre-1967 to use these adapters.
