Old 12-31-2015, 12:31 PM   #1
T and S
T and S's Avatar
Researching fuel line options, but.....
I have spent hours trying to figure this out....
I have a 250 6 cyl with a weber carb. I am wanting to run the fuel line from the fuel pump (stock) to the carb all in hard line (5/16). The weber carb does not have an internal fuel filter, just a small strainer in the inlet.
I kinda decided on a in-line anodized fuel filter with AN fittings. I have found all of the fittings I need to use except the one to adapt a steel hard line to a AN fitting....
I did find an adapter fitting that uses a nut and farrow, but it says for use with aluminum line only.
What would you guys do here ? I have spent several hours searching and looking at fittings, I think I am missing something......
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 12-31-2015, 04:43 PM   #2
T and S
T and S's Avatar
Re: Researching fuel line options, but.....
found a good write up on this page :
http://www.ka-t.org/forums/viewtopic.php?t=40354
Old 12-31-2015, 06:58 PM   #3
storm9c1
*** That's interesting ***
storm9c1's Avatar
My limited understanding of this: For flare fittings, the tube side needs to be softer than the flare nipple side so that the tubing flare can deform and seal properly to the nipple. Back in my racing days, I'd see guys doing exactly what you want to do with AN style fittings made of carbon (black) steel or stainless steel. If you use stainless steel AN fittings, then I also suggest using stainless steel tubing or NiCopp tubing. And be sure to use Teflon if you thread this into an aluminum housing since stainless steel and aluminum can gall together over time. Not a bad thing if you never want to take it back apart and/or don't want it to leak though. Your options are more limited if you want to use mild steel lines, then carbon steel AN fittings are the best bet. In this case, check the Grainger catalog or something similar.
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 01-01-2016, 11:40 AM   #4
T and S
T and S's Avatar
Good info, thanks.
