Fuel Sending unit lines ?
I have my new sending unit, it has 3 lines I will only be using the large draw line from the tank to the fuel pump.
I did away with the canisters and there is no return fuel lines. What should I do with the other two line outlets on top of the sending unit ? plug em ??? do any need to breath ??? |
I'm back with 2nd truck!
I plugged my return lines off when I replaced the fuel line to the pump from the valve on the bed rail. The other I think is a vent but I routed my vent lines together where the charcoal canisters were. I would vent one with a breathable cap where fumes go out but nothing comes in.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
#3 | |
It's a cap that goes inline. It's a vent cap like on the rear axle. It has a vent tube there as well.
Where can you buy it ?
Not sure on that. Probably a auto part store. Tell them you're looking for a cap for a line that needs to breathe but still be able to keep stuff out.
You get what you pay for
![]() Join Date: Dec 1999
I'm just wondering if you can still buy vented gas caps. They probably don't sell one to fit a unleaded fuel tank. I'm not even sure you can buy any vented caps anymore.
But, if you can, you could cap off the vent/charcoal canister line. If not, you will need a filter/cap on this line so gas vapors can escape the tank, or else it may just rip the tank wide open. I know you've seen plastic gas cans blow up like a balloon when all the vents are shut. It would cause problems it would seem to me.
Mike 1985 Chevy C-10 |
I guess I could just run the two lines out toward the body with a restricted opening so it could breath ?
Maybe use some type of filter like hog hair ??? |
I blocked off the 2 other lines (vent & return) and drilled an 1/8" hole in the center of my gas caps, to vent my tanks. Has worked fine for over 20 thou miles.
| Bookmarks |
