Old 01-01-2016, 08:26 PM   #1
donandal
High beam / turn signal indicators
I am looking for some ideas to use for my dash
in my 53 Chevy pickup.
I would like to have turn signal and high beam indicator lights.
I know some instrument companies will put LED indicators
in the gauges, but I'm looking for some other ideas first.
I plan on hollowing out the throttle and choke knobs and installing
amber and red LED's for check engine and parking brake warnings.
I just need a more period looking answer for the turn signal and high
beams, hopefully without too much cutting of the dash.
donandal is offline   Reply With Quote
Old 01-02-2016, 02:08 PM   #2
donandal
Re: High beam / turn signal indicators
I made up a piece this morning to hold 3 LED's.
two green turn signals and a blue high beam.
I didn't drill the dash yet.
What do you guys think?
Old 01-02-2016, 03:28 PM   #3
mr48chev
mr48chev's Avatar
That is the style of light I was going to suggest. I'd have cheated and drilled three holes side by side in the dash on a line where your top two are and been done with it.
My ongoing truck projects:
Old 01-02-2016, 03:38 PM   #4
donandal
I thought about that too...
I am trying to stay disciplined and not rush any details.
I want to complete all of the cab interior details before
it goes off to be painted.
Old 01-02-2016, 03:59 PM   #5
mr48chev
mr48chev's Avatar
I think I still have the three lights I bought for my truck several years ago stashed away in a box or bin waiting to be used I made the dash out of some 1-12 inch exhaust tubing and a piece of flat sheet metal in about 1981 and later put a piece of aluminum on it and was going to put the indicators in that between the speedometer and tach.
Old 01-02-2016, 10:37 PM   #6
AB6DO
You are doing the exact same thing I am doing this New Year weekend. I like your triangular shaped piece to hold the LEDs. Where did you get the LEDs? I have not found that style.
AB6DO is offline   Reply With Quote
Old 01-03-2016, 12:04 AM   #7
YukonXL04
YukonXL04's Avatar
What about moving between the colum and gauges to make it a little more subtle? I think when I do mine I will end up putting them towards the bottom of the dash or up in the defrost holes... not sure yet
YukonXL04 is offline   Reply With Quote
Old 01-03-2016, 12:24 AM   #8
Donaldo
I'm using the original high beam indicator light placement, and added green LED's for the turn indicators inside the speedometer. I like less holes in the dash.
Thanks, Don
http://www.donsbirds.com/pick-up
Donaldo is offline   Reply With Quote
Old 01-03-2016, 02:08 PM   #9
_Ogre
_Ogre's Avatar
what do you guy's think?
color me impressed
i like it
shop air compressor timer
Old 01-03-2016, 04:08 PM   #10
donandal
how did you choose the led and what are you using to dim them
for night driving?
Old 01-03-2016, 04:14 PM   #11
donandal
Interesting idea using the defrost holes....hmmm.
pretty tight in the lower area between the gauges and
column on mine. I modified it some to center the column.
Old 01-03-2016, 04:19 PM   #12
donandal
Originally Posted by _Ogre View Post
color me impressed
i like it
thanks...
I'm not completely sold on the placement yet.
I do plan on polishing and buffing the piece to look like chrome.
It's made from aluminum.
Old 01-03-2016, 05:15 PM   #13
donandal
To go along with this piece and these three LED's,
I made some new knobs. One is for the headlight.
The other two are in place of the old throttle and choke cables.
There are LED's in there also. (amber and red)
These will be check engine and parking brake indicator lights.
Old 01-03-2016, 07:15 PM   #14
47 Fasttoys
47 Fasttoys's Avatar
Looks good Donandal, now what interests me is the shifter switch indicator you've got on the lower R. side of the dash. I built a electronic shifter myself and if you care to share, I'd like to know your plans. Your welcome to mine they are posted on my build thread.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 01-03-2016, 07:29 PM   #15
donandal
Rob
I've read and reread your thread many times!
It is awesome!!!
I'm not that talented....
so I plan to buy the shift indicator from Classic instruments.
They have one in 2 inch diameter (as my cardboard pattern is
drawn) and have a sending unit that attaches to the tranny
shift arm linkage.
Old 01-03-2016, 07:39 PM   #16
donandal
I found them at Oznium.com
they are the ALUMINUM LED INDICATOR LIGHT.
I am still experimenting with resistors to add to
dim them down a bit, as I think they are too bright
for night time.
They come with one resistor already installed.
Old 01-04-2016, 12:29 AM   #17
wolffcub
wolffcub's Avatar
Make sure you have them close enough together if you put them between the gauges. I put my signal ones there first but then found out the hard way that the aftermarket gauge retainer brackets hit them. I ended up doing something simple and just installed them along the center axis from left to right with the high beam in the middle
I think that cluster you made for the middle is awesome.
You can see my two oops plugs. Will weld it up next season.
52 Chev 1300,55 235 40 over, 848 head, dual Edelbrock intake, Fenton headers, CW 32/32 carbs, 251 cam, HEI, T5 Trans, 3.23 rear, 235/75/r15 rubber.
If it aint broke I still try to fix it!
wolffcub is offline   Reply With Quote
Old 01-04-2016, 07:59 AM   #18
donandal
That looks very nice on the center line.
I think you are right about the gauge brackets also.
I'll order my gauges today, and wait til I have the brackets
in hand. Thanks for the heads up!
Did you try those LED's at night, and did you need to dim
them? The dimmer rheostat on the headlight switch I have doesn't
work with the LED, except to turn completely off or on.
Old 01-04-2016, 11:36 AM   #19
wolffcub
wolffcub's Avatar
Been driving it now for 2 seasons and they are perfect. I used the painless wiring ones.
Old 01-04-2016, 12:33 PM   #20
Donaldo
for night driving?
They are just small 12volt LEDs not a lot of lumens, they will only be lit when the turn signals are in operation....
I have never noticed dimming of turn signal indicators. I'll pay more attention next time out at night..
Thanks, Don
Old 01-04-2016, 05:14 PM   #21
donandal
I see that painless has quite a few different models.
Are those incandescent or LED, and what diameter?
Old 01-04-2016, 05:39 PM   #22
YukonXL04
YukonXL04's Avatar
Out of curiosity what is the switch above the key for? It looks great there
Old 01-04-2016, 06:00 PM   #23
wolffcub
wolffcub's Avatar
its my push button starter switch. Always glows blue. The hole above that now has my rad fan switch and its red when the fan is turned on. They fit perfect and sit perfect as the hole has the raised flat area around it.
Old 01-04-2016, 06:25 PM   #24
wolffcub
wolffcub's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=634603
Old 01-04-2016, 06:32 PM   #25
wolffcub
wolffcub's Avatar
sorry my bad.... i never used the painless ones it the the Ron F ones from summit racing
http://www.summitracing.com/int/parts/rfw-db32
