Old 01-01-2016, 08:50 PM   #1
callfarms
Need help with carb
I am having trouble with the carb on my 1953 3600. It is a 216 motor. The motor idles fine and 1/2 and full throttle are fine. When I push the foot feed just off idle the motor falters or sometimes dies. Can anyone help me out.
callfarms is offline   Reply With Quote
Old 01-01-2016, 10:23 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Need help with carb
Sounds like the accelerator pump may need to be replaced or adjusted
dwcsr is offline   Reply With Quote
Old 01-01-2016, 10:55 PM   #3
mr48chev
mr48chev's Avatar
Dave knows, yep it's time for a rebuild
A good carb kit for that carb runs about 25.00 give or take and you can get a gallon can of carb cleaner with a basket in it at O'Reilly's for under 20 bucks that you can use for a long tiime until it gets so dirty it doesn't clean more.
I'd say if you were real cheap you can get the leather for the accelerator pump and just change that but I have never pulled an old carb apart that had been together for a while that the gaskets didn't tear up on when I pulled the top off.
My ongoing truck projects:
Old 01-01-2016, 11:17 PM   #4
callfarms
Thanks guys
Old 01-02-2016, 10:13 AM   #5
Highsider
Highsider's Avatar
Soak your carb parts overnight in Ruby Grapefruit juice.
Rinse in water and dry
$3 and throw out in the wife's flowerbed.
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 01-02-2016, 11:22 AM   #6
YukonXL04
YukonXL04's Avatar
I don't get it? Lol
YukonXL04 is offline   Reply With Quote
Old 01-02-2016, 11:37 AM   #7
crossfire84
crossfire84's Avatar
Originally Posted by YukonXL04 View Post
I don't get it? Lol
The citric acid will dissolve the crud. Then compost.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 01-02-2016, 04:17 PM   #8
OrrieG
OrrieG's Avatar
When I ran the old Rochester 1 / 2 BBL on my DD I kept a kit in the parts box, knowing about every 3 years the accelerator pump would need replaced. On a truck that sits a lot, it will happen more often because the "leather" drys out. Murphy's law dictated it usually started acting up in the boonies, but I am pretty good at on the road fixes...
OrrieG is offline   Reply With Quote
Old 01-02-2016, 04:57 PM   #9
mr48chev
mr48chev's Avatar
I'm gong to try that grapefruit juice thing.
One thing I've done with the carb cleaner out of the gallon pail is to get an aluminum pan from Dollar tree that is big enough to set the carb in and pour the carb cleaner in the pan and let it soak and then lift the carb piece out of the cleaner and pour the cleaner back in the can.
Old 01-02-2016, 05:40 PM   #10
solidaxel
solidaxel's Avatar
"Does it have to be Ruby grapefruit!"
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-02-2016, 06:03 PM   #11
Highsider
Highsider's Avatar
Red face Re: Need help with carb
It looks cooler in your plastic pail.
'57 Panel 3105
Met this deer...
Jim's Bread Truck
Old 01-02-2016, 06:23 PM   #12
chevyguyase
Did this just start with the cold weather? do you still have the manual choke? If you are not use to a manual choke, you have to use a little more choke in the winter until your manifold warms up and I'm not sure if a '53 had a damper/heat riser in the exhaust manifold to speed up heating the underside of the intake manifold. If it does, make sure it works freely.
chevyguyase is offline   Reply With Quote
Old 01-02-2016, 07:52 PM   #13
callfarms
It has a manual choke. I tried running the choke on a little but didn't help. We put in a new accelerator pump and still does it.
Old 01-02-2016, 08:36 PM   #14
Virginian
Virginian's Avatar
Throttle plate should be adjusted for about .020 inch clearance to carb throat, idle mixture screw about 1 and a half turns out from closed, looking down carb with engine off, you should see accel pump shoot fuel as soon as throttle plate starts to move, could be slack in pump linkage, or worn throttle plate shaft, or you might have a vacuum leak. Also is vacuum advance unit working ? is timing correct ?
Virginian is offline   Reply With Quote
Old 01-02-2016, 09:02 PM   #15
callfarms
I can see the distributor move when you rev it up. I haven't checked timing but will. I will also check for vacuum leaks. Thanks for all the good advise.
Old 01-03-2016, 12:45 AM   #16
Coupeguy2001
Coupeguy2001's Avatar
there is supposed to be a check ball in the bottom of the accelerator pump well.
If it's missing, the gas goes back the way it came into the accelerator well, and the squirt does not go through the accelerator pump jet into your engine....so it's lean and stumbles
Coupeguy2001 is offline   Reply With Quote
Old 01-05-2016, 04:19 PM   #17
Hakang
Hakang's Avatar
I rebuilt my carburetor with a rebuilt kit and a lot of help from "Mikes carburetor" here:
https://www.youtube.com/watch?v=V2AINKEauVM
1948/50 Chevy 3100, CSB 327/TH350, M II IFS
Hakang is offline   Reply With Quote
Old 01-05-2016, 05:24 PM   #18
YukonXL04
YukonXL04's Avatar
I bought the premium version from them. Came with just about everything. Didn't watch the video but mine seems to be running good, however it hasn't been driven yet...
Old 01-05-2016, 05:41 PM   #19
1-ton of fun
polishing a turd
1-ton of fun's Avatar
have you visually verified the accelerator pump is working? does it squirt fuel when the throttle is opened? i would also verify timing. too little or too much advance can cause off idle issues.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 01-05-2016, 07:22 PM   #20
dsraven
accelerator squirt should aim right at the edge of the throttle plate as well. take a look down the throat of the carb (when engine is off) to see what exactly is going on. sometimes there can be a bit of crud in a carb passage as well. if you have a nice big rag you can start the engine and rev it up a bit with the air filter off, then stuff the rag over the top of the carb for a second and pull it off before the engine dies. the added vacuum in the carb throat will sometimes draw a small obstruction through the orifice and it will run better.
Old 01-06-2016, 08:28 AM   #21
1project2many
It sounds like Virginian has carburetor overhaul experience. With years and years of service behind them, these carbs often suffer from vacuum leaks around the throttle shaft.
How the engine reacts is helpful in determining what's happening. If you step on the gas and the engine only stumbles for a short time then recovers, kind of a Wah....rrrrrRRR as it pauses then accelerates, the problem could be accelerator pump related. But if you open the throttle slightly and hold it and the engine runs poorly the entire time, the problem could be air leaks around the shaft. In this case opening the throttle further often restores proper operation, but allowing the throttle to close to a just off idle position will cause it to run poorly again.
If you can find an older carburetor kit they are usually very complete and give you most of the tools and instructions you need for a regular overhaul. If the carb body is leaking substantially around the shaft it will need to have bushings installed.
Good luck!
1project2many is offline   Reply With Quote
