Old 01-02-2016, 01:31 PM   #1
Dibdob62
Dibdob62's Avatar
Another Temp/Fuel Gauge Problem, Sorry :(
My recently acquired 1970 C10 had a new gauge cluster fitted it also had a new under bed fuel tank fitted when it landed over here in the UK but the fuel gauge has always read 3/4 full and the temp gauge only moves up to the first cold line.
I fitted a new temp sender and nothing changed but I did notice that the PO has fitted an earth wire to the top terminal of the gauge to the cab and if I disconnect it the needle pings to hot.
As for the fuel gauge I removed the wire connected to the "fuel Ga" pin in the fuse box and the needle moved round to the 3 0clock position passed the full position.
I'm thinking that the gauge cluster may not be earthed so can some one put a picture up showing where the earth wire should be attached to the cluster please.
Dibdob62 is offline   Reply With Quote
Old 01-07-2016, 04:50 AM   #2
Dibdob62
Dibdob62's Avatar
Re: Another Temp/Fuel Gauge Problem, Sorry :(
Anyone ?
Old 01-07-2016, 01:26 PM   #3
kehstr
kehstr's Avatar
if you have pictures it will help me diagnose it
kehstr is offline   Reply With Quote
Old 01-07-2016, 01:50 PM   #4
70STOVEBOLT
70STOVEBOLT's Avatar
I don't have a pic of the ground wire, but it comes out of the 12-pin cluster connector and just has a clip on it that clips to the metal dash below the cluster.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
