Old 01-02-2016, 10:07 PM   #1
mgb
mgb's Avatar
5 in. drop front
How can I drop my 68 5" in front and keep my drum brakes. Also, how do I change front drum and hub to 5 lug?
mgb is offline   Reply With Quote
Old 01-02-2016, 10:10 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: 5 in. drop front
Get 5 lug disc brake spindles and rotors. New 5 lug axles out back.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 01-02-2016, 10:43 PM   #3
leftybass209
leftybass209's Avatar
Gary
This is what's available for 5 lug. What 5 lug drum brakes did you plan on running? You can do 6 lug drums with drop spindles, and re-drill the hub and drum for 5 lug I guess. Trucks switched to 5 lug disc in 71. Some cars have 5 lug front drums but no one I know of has posted trying to utilize those with truck spindles.
leftybass209 is offline   Reply With Quote
Old 01-02-2016, 11:13 PM   #4
mgb
mgb's Avatar
Do you know of a drop spindle I can use with drum brakes? That's what I would prefer to do.
Old 01-02-2016, 11:47 PM   #5
leftybass209
Early Classic Enterprises, Performance Online, CPP.... any of them should have drop spindles for drum brakes. There's a few others too.
Old 01-03-2016, 11:51 AM   #6
Green67Stepper
Green67Stepper's Avatar
i'm pretty sure all drop spindles have to run discs.
DJM has some drop lower control arms that you can run to get down to 5" with the stock spindles and drum brakes.
https://djmsuspension.com/product-ca...0-6372rcs-kit/
Green67Stepper is offline   Reply With Quote
Old 01-03-2016, 06:42 PM   #7
leftybass209
Stupid me.... you are of course, correct. There aren't any drop spindles for drum brakes.
