Old 01-03-2016, 11:49 AM   #1
Sandemonium
Proud owner of a 55.1 AD
Sandemonium's Avatar
Blazer / Jimmy EFI Gas Tank
Looking for a replacement tank for my Jimmy that has the pump mounted in the tank. I know Boyd and No Limit both make tanks for trucks, but does anyone make a tank specifically for the Blazer / Jimmy?
While searching I have seen a couple of people have used the side fill tanks for trucks, but I'm not sure that is the best solution. It seems that for the truck tank to work well on a Blazer / Jimmy the side fill would need to be moved a little farther forward on the tank. What other changes would need to be made for a truck side fill tank to be used on a Blazer / Jimmy?
Sandemonium is offline   Reply With Quote
Old 01-04-2016, 03:07 PM   #2
cleszkie
cleszkie's Avatar
Re: Blazer / Jimmy EFI Gas Tank
I installed an Aeromotive Phantom in-tank pump kit to support my fuel injection. A little spendy, but it can be installed on any tank to keep the inlets where you need them.
cleszkie is offline   Reply With Quote
Old 01-04-2016, 03:13 PM   #3
Sandemonium
I briefly looked into that setup. You're right, it is spendy. I was just hoping an aluminum tank would be available from someone.
