01-04-2016, 06:59 AM | #1 |
Building a 1980 extended cab Chevy?
I've been searching 2 days for build threads on how to convert an 80's Chevy pickup into an extended cab but I can't find any. Could someone lead me in the right direction? I'm wanting to build a chore truck to feed cows. I'm wanting to make an extended cab longbox.
01-05-2016, 12:51 AM | #2 |
Re: Building a 1980 extended cab Chevy?
I would take a crew cab frame and shorten the cab and frame,Or if you got the time and money you can buy a extended cab truck a few companies made these back when these trucks was new.
01-05-2016, 01:18 AM | #3 |
I've been trying to find one for sale with no luck
01-05-2016, 05:16 AM | #4 |
You could become a forum supporting member and place a add in the wanted to buy.
01-05-2016, 06:05 AM | #5 |
What do you mean by forum supporting member
01-05-2016, 06:39 AM | #6 |
See up top where it says subscribe on this forum ?
01-05-2016, 07:45 AM | #7 |
I think now that you are hooked up with this site you will start seeing them; there are several ext cab enthusiasts that often post when one (not theirs) comes up for sale.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
01-05-2016, 09:05 AM | #8 |
01-07-2016, 11:40 PM | #9 |
These guys are going to do something with an extended cab.
http://bangshift.com/general-news/pr...hevrolet-c-10/
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
01-08-2016, 01:13 AM | #10 |
At the body shop.
Long bed frame short bed , bob the rear rails and stretch the cab to the bed.
" That didnt make it any newer " " Dont antique the equipment " |
01-08-2016, 09:40 AM | #11 |
yeller
That is the way to do it...unfortunately, all the coach built units just shortened the front of the bed...and that looks like crap.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
01-08-2016, 04:13 PM | #12 |
'83 Silverado Step Side '85 GMC short bed. '86 Chevy Step Side Custom Deluxe LQ9/4L80 swap (SOLD) |
09-15-2016, 02:12 PM | #13 |
I just spotted this one in Barrow Alaska.
It has Silverado 10 badges, no extra Windows, 8 lug axles, and a wrecker in the bed.
CHEVY ONLY |
09-17-2016, 09:34 PM | #14 |
I think if i was to build one id use a k5 body on a longbed frame that way i allready had the roof and side structure all there then just cut the length you like and weld on the rear portion of a c10 cab. The side windows would be the only tricky part but im sure they wouldent be that bad. Id measuse up a bunch of trucks and find ones with ext cab windows the same height as a c10 and just cut around them a couple inches and weld that into your cab. Then you would have opening rear windows with easily replaceably glass.
09-18-2016, 11:43 AM | #15 |
I had started a thread about this several years ago and to build one from scratch the easiest way would be start with a crew cab chop the doors down x amount of inches then shorten the cab. Cut the b pillars weld them to the back doors and then find some suicide hinges for the back doors to open like a regular extended cab would.
Install a 90s or 2000s rear extended cab seat and modify the stock door panels to look decent. Also to shave the rear door handles and install the ones into the b pillar so they open like current extended cabs. Then either shorten the frame to run the stock bed or build a flatbed for it. But shortening the frame would also include a new/ modified rear driveshaft. My plan was and still is if I find a crew cab that is clean enough is to shorten it just enough to get rid of the window in the back doors that stay stationery then the body line around the window will still match the truck unlike the ones that were build from the coach companies It would definitely be a long build to make everything look nice
1987 v20 regular cab - work in progress swapped in a (1992 tbi 350 with vortec heads) old motor. currently has an 8.1l and 4l80 swap. flatbed bed 2 inch lift and 64 inch spring swap in the rear. 2002 chevy 2500hd extended long- blackbear tune. DD |
