Old 01-04-2016, 01:26 PM   #1
Henner
Will these wheels fit 68??
I am fixing to order new wheels and tires for my 68 short box. Before I do any ordering I want to make sure I have all my ducks in a row. I plan on running Toyo Proxes STII Front, 255/40/20 Rear, 295/40/20
I am wanting to run the Ridler 695 20" as described below. Will this wheel work with the following specs??? I think i'm concerned with the hub bore issues.
Name:  04-Jan-2016 11-19 .jpg
Thanks,
Henner is offline   Reply With Quote
Old 01-04-2016, 03:42 PM   #2
cdowns
cdowns's Avatar
Re: Will these wheels fit 68??
does your 68 have 5lug wheels on it now??
Old 01-04-2016, 03:52 PM   #3
Henner
Yes sir it does. But was talking to a local wheel shop and they said the 83 hub bore would not work on my truck.
Old 01-04-2016, 04:15 PM   #4
trkfrk
trkfrk's Avatar
If the hub bore is the only issue and you're set on running those particular wheels, maybe turning down the front hubs may be an option. All of us that are running the Boss 338's had to do this.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 01-04-2016, 04:55 PM   #5
Henner
I am not exactly sure if the hub bore will be an issue just wanting to make sure before ordering them. Do you guys running the 338's remember the bore on that rim?
Old 01-04-2016, 06:00 PM   #6
Henner
Forgot to mention the truck is a step side so not sure if I would be able to run a 295 and it be able to tuck in the wheel well??
Old 01-04-2016, 06:21 PM   #7
chiefcfd
chiefcfd's Avatar
I am running these Ridler 18X8's on my "72. I have no clearance problems.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 01-05-2016, 02:24 PM   #8
What year is your Stepside? Just wondering if you have the wider or narrower housing
Old 01-05-2016, 02:58 PM   #9
Henner
1968
