62/63 spindles
what is the difference between 60-62 spindles and 63-70 spindles?
Scott 63 C10 Stepside 230 1bbl Saginaw 3 spd |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 62/63 spindles
ball joint and tie rod taper sizes,... since the 60-62 were designed for the torsion bar front suspension a-arms.
Re: 62/63 spindles
How about the brake shoe anchor bolt? I just got a disc brake kit for my 63. The hold down bolt at the top of the spindle for the anchor is 5/8 fine. The bolt with the kit is 3/4 fine
Top hole ![]()
Scott 63 C10 Stepside 230 1bbl Saginaw 3 spd Last edited by scott657; 01-04-2016 at 08:13 PM. |
Re: 62/63 spindles
Brake "shoe" anchor bolt?
On a disc brake spindle? I'm not following you.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: 62/63 spindles
I believe he bought the kit to convert a stock '63-'70 spindle to disc brakes. It comes with a bolt on caliper bracket that utilized the top brake anchor pin hole and one of the lower steering arm bolts.
#6 | |
Re: 62/63 spindles
I see that now. Doesn't that kit make you switch to chevelle rotors with the 5x4.75 bolt pattern?
Re: 62/63 spindles
yes, it seems my spindle is an oddball, nothing a sleeve and a bolt can't fix
#8 | |
Re: 62/63 spindles
These use 71-87 HD 5x5 rotors and calipers, like the 63-70, 71-72, and 73-87 trucks use. To me,... this is a better option than converting to 5x4.75" bolt pattern with the stock drum brake spindle.
