axle swap
I have a 2000 S10 blazer rear end, I'm wanting a 5x5 bolt pattern, is this as simple as just swapping the axles from the 5x4.75 to 5x5?
"Fear makes the wolf look bigger" http://67-72chevytrucks.com/vboard/s...d.php?t=305629 |
Re: axle swap
What are you swapping it in to ?
Re: axle swap
It's going in a 59 gmc, the front is 5x5 already.
Re: axle swap
Might be cheaper and easier to change the front lug pattern,Or find a different axle in in the size and bolt pattern you want.
Collector of Projects
Re: axle swap
Astro Van/Safari have the 5x5 bolt pattern, see if you can swap parts... or a 94-96 Impala / Caprice had the 5x5 and disc brakes....
Re: axle swap
Those axles are gonna be wider than the S-10. You can redrill the drum and flange, or convert to disc and order new axles with your pattern.
2000 Chevy Tahoe Limited 3/5" drop 2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon stock SAS 6" |
Re: axle swap
Its already a disc brake rear..just has a 5x4.75 pattern. Can you redrill the axle hub to a 5x5 or would that not be prudent in this juncture
Re: axle swap
/should be able to
| Bookmarks |
