![]() Join Date: Aug 2013
Quick and Easy Fix for Exterior Door Handles
I'm restoring a 1967 GMC and decided to have my exterior door handles re chromed. The problem with these door handles is that it's impossible to disassemble them without breaking the tabs that hold the plunger in place. I came up with a cheap solution that j wanted to share because these break a lot also and this is a cheap alternative to buying new handles. I picked up a piece of 1 inch aluminum tubing from Menards for a few dollars.
![]() I cut a 1 1/4 inch chunk off of it then cut that piece down the middle. ![]() Then I drilled a hole for the plunger and fit the piece inside the door handle. The opening is tapered a little bit so you have to grind one end to get it to fit properly. I put the plunger back in the door handle followed by the spring then used some aluminum rivets to hold the whole thing in place. ![]() ![]() There you have it. Just a few dollars and about 15 minutes and your door handle is better than new.
1949 Chevy 3100 Five Window 1964 Chevy C10 Lambrecht Auction project 1967 Chevy SWB K10 1967 GMC K15 Project Build thread- http://67-72chevytrucks.com/vboard/s...72#post6502772 1968 Chevy Anniversary K10 1991 K5 4" Lift 35's (the wife's toy) |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: Quick and Easy Fix for Exterior Door Handles
That's pretty slick. Thanks for sharing the idea.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
Nice job its well done an should last.
I could've used this fix 2 months ago on a 71. Instead I used a 67 handle on it. Witch is something I didn't wanna do. Its these kinda threads that makes this board so great. Thanks for sharing
81 camaro 355 4/spd 342 posi my first love .67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
Nice innovation and great pics.Thnaks
![]() Join Date: Apr 2005
Nice job!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
laying low
![]() Join Date: Mar 2001
That's good thinking and looks like it will hold up for a long time too.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver 'primer is finer' Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
The best thing about the way the door handles work on these trucks, is if it does happen to brake, you can still open the door without the button, I've done it a few times, just being to lazy to change the handle.
Thanks for this solution. Another quick solution (when still having the square plates) can be done by two electric wires (cupper 2.5mm).
I'm gonna try this, the plunger on my passenger door fell apart recently. Thanks for the info!
Nick 1972 Chevrolet C10 Stepside |
Thank you! The PS handle on our 72 popped apart this week. Using your idea, we just bent up a piece of 14ga steel since that's what we had, and use #8 flat head sheet metal screws, countersinking the handle. Installed no problem, works great.
Appreciate the great advice, HuntzNSam |
Hope to never need this, but if I do...
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
![]() Join Date: Apr 2016
Excellent Idea. I have a couple broken handles I've been thinking of rebuilding and was thinking of bending something up and doing something similar. I like just cutting some square tubing better.
1972 GMC K2500 Super Custom Matt |
#13 |
![]() Join Date: Mar 2013
Awesome innovation. Thank you!
Justin '67 C20 CST Custom Camper '04.5 LLY Duramax CCSB...sold |
#14 |
Can the rivets be substituted with self-tapping screws?
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion |
#15 |
I think that would work, but....clearance in the handle opening may be a problem getting the handle back thru sheet metal.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
#16 |
I have two handles in service right now with the wire like in the above post and it works fine.
| Bookmarks |
