Old 01-05-2016, 10:07 AM   #1
Tdrcreyn4
Tdrcreyn4's Avatar
What is the right Switch?
I have a factory NL2 option auxiliary gas tank set up ready to be installed in my truck and the switch I got with it was a standard toggle switch like most I have seen. Yesterday I saw this switch posted and sold on the parts board (SEE BELOW). Can anyone tell me what came stock with this option? Did it depend on what plant it came out of, etc, etc...... I want the correct switch for my truck and had never seen the one below until yesterday.....
Thanks,
Todd
1968 C10 292/3 spd - sold
1969 K10 350/3 spd/205 - sold
1971 K5 350/4 spd/ 205 - sold
1970 K20 350/350/205 - sold
1969 K20 396/400/205 - work in process
Tdrcreyn4 is offline   Reply With Quote
Old 01-05-2016, 10:51 AM   #2
dazza
dazza's Avatar
Re: What is the right Switch?
I'm not sure how(or if) they came from the factory, although I believe most were dealer installed. Here's mine as well as the tank valve mounted on the floor between seat and door.
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
Old 01-05-2016, 11:45 AM   #3
RenoKeene
Florida Edition
RenoKeene's Avatar
I believe the correct switch is the one shown in the pic you posted. Here is a pic of the one that was in my 72 Custom Camper...
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 01-05-2016, 01:13 PM   #4
jocko
jocko's Avatar
Concur, correct NL2 fuel gauge selector switch is displayed in first post. Travel Tanks are aftermarket or dealer installs. The floor fuel selector valve only directs flow, it's unrelated to the dash fuel gauge selector switch.
Old 01-06-2016, 11:53 AM   #5
Tdrcreyn4
Tdrcreyn4's Avatar
Thanks Guys, Now to find one.
Old 01-06-2016, 05:45 PM   #6
dazza
dazza's Avatar
yes, the valve is physically unrelated and has nothing to do with your correct switch question, just need to remember that it's not unrelated when you use either one...you need to use both, unless of course you're playing a trick on somebody!
btw, Does the factory valve look the same as the Travel Tanks valve?
Old 01-06-2016, 08:03 PM   #7
Tdrcreyn4
Tdrcreyn4's Avatar
Here's the valve. Don't know what the saddle tank bags valves look like.
