01-05-2016, 11:03 AM | #1 |
transfer case id
I found a 241c I'm hoping will work for my 4l60e only down fall its 3 hours away. It was behind a 700r4 so should be 27 spline. could someone tell me if its correct thank you
241c 1561 4199 1 16 90 3 272 |
01-05-2016, 11:21 AM | #2 |
Re: transfer case id
Most likely it is a 241c
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
01-05-2016, 11:42 AM | #3 |
The pictures attached are of the 241C I rebuilt. it is from a 91 Suburban. it is connected to a 2008 4L60E. it has a 6 bolt adapter to connect the TC to the Transmission. The 91' TC has a VSS sensor on the tailshaft output. I think the 89/90 and earlier did not.
The 700R4 I think is a 4 bolt flange. So if you have the correct mount you should be fine and yes it should be 27 spline.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
01-05-2016, 12:08 PM | #4 |
I have the stick 4l60e adapter I notice the serial number was different guessing each case has a different serial number?
01-05-2016, 12:09 PM | #5 |
Oops stock
01-05-2016, 12:15 PM | #6 |
This is a picture of a label on a TC and its discriptions
01-05-2016, 05:34 PM | #7 | |
01-05-2016, 05:38 PM | #8 |
Yes from the same 91 suburban.
01-10-2016, 12:29 PM | #9 |
First c10 think I could get a little more info on your t case setup? I picked up a w style crossmember,do they need the spacers to bolt to the frame? Also I notice a rod that goes from transfer case to somewhere else. From what I've heard its a support bar am I correct? Does the case need any other kind of support? Thank you in advance
01-10-2016, 12:46 PM | #10 |
Check out my build thread. It has pictures of the rod and crossmember. Also has information. Around post 201
01-10-2016, 12:56 PM | #11 | |
It is a 2008 4.8 with 4l60e trans. It has a 1991 241c t case attached to it. I used the cross member from the 1991 and the support rod. I had to lower the crossmember with 1" spacers to get my angles correct. I am responding from my phone so hope it makes sense.
01-10-2016, 01:02 PM | #12 |
no it makes sense and you answered my questions. I will defiantly check out your build thread. from just the pix ive seen looks like its going to be a clean truck
thanx again |
01-11-2016, 12:08 AM | #13 |
got another great question. my k5 has a 4 inch lift. should I do a slip joint eliminator on the NP241 I'm going to install? my stock 203 has it.I don't do no crazy 4 wheeling. just a few trailers here and there and the snow when we get it LOL
01-11-2016, 12:40 AM | #14 |
I didn't bother since I was not going to be rock crawling. But I am not the expert on them. Also for some reason I remember something about them not making an eliminator for the 241. But maybe I am mistaken. I guess it would be worth it only if it is a benefit for your applications and uses.
01-11-2016, 12:55 AM | #15 |
They make one, but don't think it's needed for what you wanna do. If you have a lot of lift, do some hardcore wheeling then it might be advisable.
01-11-2016, 01:05 AM | #16 |
I'll skip it then. I seen them for around $200
04-24-2016, 05:33 PM | #17 |
I notice my transfer case has 2 sensors. I know one is the VSS does anyone know what the other on is?
04-24-2016, 06:46 PM | #18 |
Rear of the tc is the VSS. The other is up towards the shifter. It is the 4x4 indicator. It closes a contact when you are in 4wd.
04-24-2016, 07:13 PM | #19 |
Funny after I posted it I started to read a post you had replied on. I'm running a 4l60e and I'm probably going to gave to do what you did with the sensor
