09-19-2003, 04:30 PM | #1 |
recalibrating the speedo?
Is there something that I can do that will allow my speedometer to tell me how fast I am actually going?
84 Silverado, |
09-19-2003, 05:24 PM | #2 |
isnt that what a speedo does? i assume it isnt accurate due to larger tires? there is a certain gear you need instead of the one you have. the other more knowledgable guys around here will know which one or a webpage that shows it. just replace the one in your trans/tcase depending... i think 4x4 is tcase... might try www.73-87.com alot of answers can be found there!
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
09-21-2003, 07:27 PM | #3 |
Professional Grade
Another speedo question, is the gearing going to be significantly different from an 85 MPH to 100 MPH speedo?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
09-21-2003, 11:46 PM | #4 |
BAD BOW-Silverado XST
No. The magnetics that actually turn the speed are calibrated.
This is the best speedo gear calculator I have found. Just measure your tire. Then find a combo that gives the closest whole number for a driven gear. |
09-22-2003, 12:13 AM | #5 |
Professional Grade
So trading a 85 mph and a 100 mph speedo won't affect the accuracy?
09-22-2003, 12:39 PM | #6 |
I'm back with 2nd truck!
No not at all. Like Gerado said they're made inside the speedo itself calibrated to the speedo itself. Basically it means the "gearing" inside the speedo is calibrated differently to each 100mph or 85mph speedo.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
09-22-2003, 04:36 PM | #7 |
speedo...
I second the TCI page... that's the one i used. I had calculated that using a 31inch tire, a drive gear w/ 41 teeth and a driven gear with 17 teeth was pretty darn close. Went to the local GM center and ordered the parts. you can cross reference gear tooth availability on TCI's page for the tranny you're using.
good luck, Keith (btw those numbers up there are from memory, may wanna double check it if you've got 31's) :-)
true power comes from above!!! 1984 C/10 2wd SWB. |
09-22-2003, 07:52 PM | #8 |
Professional Grade
Sweet deal Just gotta lube up that new speedo next time I take apart my dash to rattle can the back a reflective silver to get rid of the bouncing needle sydrome...
