Old 01-05-2016, 04:57 PM   #1
Laid_Out_50
Laid_Out_50's Avatar
Bare Metal
So I've decided that I want to run my truck in bare metal. I know I have the rust issue but is there any away to keep the rust away. I was told clear coat but read that eventually it would rust under the clear coat. Than I was told about Gibbs Oil apply about once a month and the rust will not appear. What's your guys take on this
Laid_Out_50 is offline   Reply With Quote
Old 01-05-2016, 06:01 PM   #2
Donaldo
Re: Bare Metal
I think you are way too close to that big salty pond - rust never sleeps !
Thanks, Don
http://www.donsbirds.com/pick-up
Donaldo is offline   Reply With Quote
Old 01-05-2016, 06:37 PM   #3
1-ton of fun
polishing a turd
1-ton of fun's Avatar
Re: Bare Metal
mild steel rusts, except in Arizona.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 01-05-2016, 09:03 PM   #4
Advanced Design
Advanced Design's Avatar
Re: Bare Metal
In 2011 I almost bought a Suburban that was in Panama City Beach, Florida in bare steel. The owner used WD40 on it. Unfortunatley I didn't buy it.
Fast forward a few years and I stumble across it here, owned by a member. He used linseed oil.
http://www.67-72chevytrucks.com/vboa...d.php?t=612572
It still looks good.
Advanced Design is offline   Reply With Quote
Old 01-05-2016, 09:06 PM   #5
Donaldo
Re: Bare Metal
""He used linseed oil.""
Be sure to use 'Boiled" Linseed Oil so it will dry. Penetrol also works well on bare metal.
Thanks, Don
Old 01-05-2016, 09:18 PM   #6
Foot Stomper
Foot Stomper's Avatar
Re: Bare Metal
There's no cure for loose scaly rust. Period. But if you have visual rust, you can clear it....maybe. I say "maybe" because clear is designed to stick to paint, not bare steel.
Here's the rust/adhesion test. Take a paint scraper, scrape on surface while holding a white towel or Kleenex to catch falling debris. If you see debris, keep scraping/wire brushing/sanding. If there's no debris, then you are good to give it a try.
Rust can't grow without air and moisture. WD40 would work for a short period of time. Heavier oils/grease will work too. Clear coat should work too if you have a clean abraded surface.
If time is on your side, do a test a panel.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 01-05-2016, 11:28 PM   #7
mr48chev
mr48chev's Avatar
Re: Bare Metal
Another fad I don't understand but from what I have read on it a lot of WD-40 and scotchbrite pads and elbow grease if you want to keep it looking like bare metal rather than rusted metal.
My ongoing truck projects:
Old 01-06-2016, 10:49 AM   #8
58CameoAZ
Re: Bare Metal
Hate to say this, But Rust finds its way into Arizona! maybe not as much,
but it is here, Trust me i Know!
Its a Dry Rust Though
Allen
58CameoAZ is offline   Reply With Quote
Old 01-06-2016, 02:51 PM   #9
OrrieG
OrrieG's Avatar
Re: Bare Metal
Sounds like a lot of maintenance to me. Like the billet guys that drive their car or truck on a weekend cruise then spend all week evenings detailing the under carriage. I just want to be able to drive mine daily and hand wash it every couple of weeks and hit the under carriage with low pressure washer when I go off road or drive in winter. Also around here there is so much dust and pollen that anything remotely oily would give you more of a velour or suede finish....
OrrieG is offline   Reply With Quote
Old 01-06-2016, 03:33 PM   #10
67GMCkid
67GMCkid's Avatar
Re: Bare Metal
Boiled Linseed Oil,
My old man used that 50 years ago to thin oil based house paint and as a finish over top of the stain as a clear on gun stocks..
To this day just the metion of the stuff and I can vividly smell that horrible stench..
67GMCkid is offline   Reply With Quote
