Old 01-05-2016, 09:59 PM   #1
Rickysnickers
Power steering
I have had my truck since November 2014. I have been battling an oil leak. I've replaced several gaskets that I knew weren't working. However within the last week, I was reading a thread here about power steering.
Someone mentioned that the old Chevy power steering pumps ran too much pressure for the T-bird racks. This same person said Speedway sold a pressure reducer. I had replaced the rack when I got the truck. The boots were all cracked and there was fluid all over the place. I didn't really think about it being overpressurized. Anyway, I bought the reducer and installed it today. The old one I pulled out was not a reducer. I'm hoping this will stop the leak.
I don't remember the member's name that mentioned the part, but thank you!
Old 01-05-2016, 11:21 PM   #2
mr48chev
mr48chev's Avatar
Re: Power steering
The pressure reducer is intended to get away from the twitchy (for a lack of a better term) sensation with that rack using the Chevy pump.
It was my understanding that certain T bird racks were compatible with the Chevy pump though.
My ongoing truck projects:
Old 01-06-2016, 04:03 PM   #3
_Ogre
_Ogre's Avatar
Re: Power steering
the speedway reducer may fix your oil leaks in the rack too, unless the o-rings are to far gone
while my main problem was twitchy steering the rack was leaking until i installed the reducer
shop air compressor timer
Old 01-06-2016, 05:35 PM   #4
Rickysnickers
Re: Power steering
I'm hoping for that Ogre, the oil leak. But, yes the steering was a little twitchy too.
Old 01-07-2016, 09:22 AM   #5
72Mountaineer
72Mountaineer's Avatar
Re: Power steering
This may be a little off-topic, but will a GM type II PS pump work with a TBird rack?
72Mountaineer is offline   Reply With Quote
Old 01-07-2016, 11:07 AM   #6
Coach529
Coach529's Avatar
Re: Power steering
I will be putting a Ford Rack in......so following along....
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 01-07-2016, 11:16 AM   #7
Coach529
Coach529's Avatar
Re: Power steering
Another option:
https://www.borgeson.com/xcart/home.php?cat=83
1949 Chevy 3600
Old 01-07-2016, 11:52 AM   #8
Rickysnickers
Re: Power steering
Yes, it appears you can. I Googled that power steering pump and just went to the first site that popped up. They low pressure valve for the type II pump, http://www.tuffstuffperformance.com/...od/prd9697.htm
Old 01-07-2016, 11:59 AM   #9
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Power steering
Yes but you still need to use a reducer on any ford rack.
dwcsr is offline   Reply With Quote
Old 01-07-2016, 04:56 PM   #10
Coach529
Coach529's Avatar
Re: Power steering
Is there a performance difference between a GM type II PS pump with a reducer vs a Borgeson pump set up for Ford??
1949 Chevy 3600
Old 01-08-2016, 09:59 AM   #11
Coach529
Coach529's Avatar
Re: Power steering
http://www.speedwaymotors.com/Heidts...lve,14895.html
1949 Chevy 3600
Old 01-08-2016, 04:40 PM   #12
_Ogre
_Ogre's Avatar
Re: Power steering
if i had it to do over...
i'd use the ford pump
Old 01-12-2016, 06:12 PM   #13
Rickysnickers
Re: Power steering
The Speedway restrictor is great! I had no idea how twitchy the steering was. I cannot do one finger u-turns, but that's ok! I wish I had known about this sooner. Also, the front of the engine seems to be dry, so far, so maybe that was the leak I had been chasing as well. Fingers crossed.
Old 01-13-2016, 03:15 PM   #14
_Ogre
_Ogre's Avatar
Re: Power steering
thanks for the feedback
glad it worked out for you
Old 01-13-2016, 09:30 PM   #15
Gundu7475
Re: Power steering
I'm currently in the process of restoring my 1955.1 Chevy 4400. My question is about power steering. I'd love to put power steering in the truck but not sure what fits and what doesn't. I'm obviously new to this. I've gotten some parts from classic parts and old Chevy trucks and the people on the phones aren't too sure if the parts that they typically sell (for smaller trucks 3100,3600 etc) will fit my truck. It's a 1.5 ton. Thanks for any help. I need to know exactly what to buy to make the conversion. Thx again.
Gundu7475 is offline   Reply With Quote
