Old 01-06-2016, 09:47 AM   #1
philobeddoe
philobeddoe's Avatar
Vibration/shudder from engine
Under load, like going up a hill or just plain accelerating, I feel a vibrate/shudder coming from engine. I can also feel it in park when I give it gas. No matter how fast going down the road, if foot is off the gas it is very smooth. It is also smooth at idle.
I'm stumped! Plugs and wires were changed when I had valve seals done back in Sept. Could it still be a bad plug or firing order, I guess I would have noticed before then? Maybe a plug got bad since? Timing, hoses??
I'm stumped! Thanks for all help.
Philippians 4:8, Victory through pure thoughts.
philobeddoe is offline   Reply With Quote
Old 01-06-2016, 12:20 PM   #2
jjmorrse
Re: Vibration/shudder from engine
Did the row of black widow bikes you knocked over damage the harmonic balancer? Did Clyde check the accelerator pump? That is all I have, sorry.
jjmorrse
86 C30 crewcab big dooley. 454- 400
jjmorrse is offline   Reply With Quote
Old 01-06-2016, 12:31 PM   #3
Matt Man
Matt Man's Avatar
How are the condition of the motor mounts?
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 01-06-2016, 01:13 PM   #4
Dead Parrot
Check your plugs. They should all look similar. If one or more are different, those are your suspect cylinders. Did you replace the cap with the wires? Could be the cap, rotor or the button in the cap.
An almost plugged fuel filter will cause cutouts under load.
To eliminate accessories, remove all the belts and do a brief retest in park. If the vibration goes away, one of the accessories is suspect. Keep in mind, no belts, no water flow so keep the tests under a few minutes.
Dead Parrot is offline   Reply With Quote
Old 01-06-2016, 03:41 PM   #5
philobeddoe
I will start with the plugs, and try it without belts. We did replace cap and wires. Thanks.
Oh, i bet the black widows messed with it! Lol, any which way but loose!
Old 01-06-2016, 04:09 PM   #6
mMad Dawg
Question Re: Vibration/shudder from engine
Did you do a compression test. You may have a low cylinder. Did it start to miss after you did the plugs. You may have a bad wire that got damaged when you pulled them off the plugs. Did you check the wires with an ohmmeter.
mMad Dawg is offline   Reply With Quote
Old 01-06-2016, 06:37 PM   #7
philobeddoe
Well here is what happned, i checked plugs and all were clean, so i wire brushed anyway. Then ran engine without fan belt, it seemed still shuttery NOT hesitating or skipping, then when i put the belt back on i took for a test drive and seemed pretty smooth. Now i'm more confused!!!
I guess time will tell on this one.
Oh, and it was the same when i checked after cleaning the plugs.
Old 01-06-2016, 06:42 PM   #8
Zach079xxx
Zach079xxx's Avatar
Check your fuel filter, maybe it's not getting the fuel it needs at high RPM. Air cleaner nice and clean? What about your plug wires? and engine mounts ok? Hmmm.. what's the story behind the black widow bikes? Or am I missing the joke lol
85' GMC Sierra Classic
Built 350; Weiand intake, Holley 600, Thumpr Cam
Built 350 turbo with shift kit & 2500 Stall
Thumpin' away
Zach079xxx is offline   Reply With Quote
Old 01-06-2016, 07:01 PM   #9
philobeddoe
The black widow thing is the gang in the two clint eastwood movies, "anyway which way but loose" and "any which way you can". Philo beddoe was clints character.
Plugs are good, wires are good. Will check fuel filtr, but i dont think thats it. It does not skip or hesitate at all.
Question, should the harmonic balancer be "pin" straight? I can see a little movement in mine.
Old 01-07-2016, 06:19 PM   #10
jjmorrse
This thread has several obscure things that might be worth checking.
http://www.jalopyjournal.com/forum/t...ration.836151/
jjmorrse
Old 01-07-2016, 08:16 PM   #11
philobeddoe
Yeah, that's a good thread, I have a good mechanic taking a look at it, a lot is pointing to the h. balancer. Will certainly post results.
