Old 09-19-2003, 05:09 PM   #1
J.Lance
Too many is never enough!
'68 tow hooks
Need some verification please. Got my new hooks in the mail yesterday and they look great. Only problem is I believe they are for the same side as they curve the same direction and are identical to each other. Just got a pm from Randy (teeitup) and he said his hooks curve different directions and was told they mount so they curve to the inside. He also recommended that I ask for a second opinion so here I am. Any verification would be helpful.
I'm pretty sure that is the case, anyone else out there running around with the same side '68 hooks?? Maybe a trade is in order.
Thanks!
Jason
1968 K10 SWB Fleetside
1971 K2500 GMC LWB
1968 K20 (later frame, donor body)
1972 C20 LWB parts truck
1993 K2500 Suburban, tow rig, 454, 4L80E
NEW!! 18' Siem's car hauler
2004 Honda Odyssey (family man!)
J.Lance is offline   Reply With Quote
Old 09-19-2003, 05:20 PM   #2
Randy70C-10
Randy70C-10's Avatar
Have you asked the person that mailed them to you, maybe he has 2 pair and sent you two of the same side by mistake?
Randy70C-10 is offline   Reply With Quote
Old 09-19-2003, 05:30 PM   #3
J.Lance
hooks
That is exactly what I'm hoping and I've sent a pm but haven't heard back yet. (it's only been about 15min. though)
Jason
1971 K2500 GMC LWB
Old 09-19-2003, 05:36 PM   #4
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Original 68 hooks will curve opposite each other, there is a 71-72 style that both curve in the same direction, can you post a pic of them.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 09-19-2003, 05:47 PM   #5
J.Lance
pic
I'll try to post a pic tonight. Pretty positive they are '68 style. Look just like the ones that Randy posted pics of a while back. (ones on the right). Here is a link.
http://67-72chevytrucks.com/vboard/s...threadid=68973
Jason
1971 K2500 GMC LWB
Old 09-19-2003, 05:54 PM   #6
BLAZERMAN
BLAZERMAN's Avatar
It sounds like you may have gotten 2 of the same side.
Old 09-19-2003, 06:45 PM   #7
mkmiller1
mkmiller1's Avatar
SORRY!
Bummer Jason, This is the first I've heard of these hooks that I sold are supposed to turn opposite ways. I've sent you a couple of PM's. Don't worry I'll make it right!! I'm just wondering how I got 2 that turn the same direction??? I've only owned one set of this style.
Thanks,
Matthew
I do remember the #'s on these hooks being correct for 67-70.
GOD is good...All the time!
'71 swb custom10 barn find-68K original miles
72 K5 CST rust bucket, but runs and drives 84K miles
mkmiller1 is offline   Reply With Quote
Old 09-19-2003, 10:00 PM   #8
Rod
Heat it up and bend it if you want it the other way.... I'll try one of mine first if you like. Rod
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 09-19-2003, 10:19 PM   #9
Rod
The hooks have the same number on each hooks... so its the same hook just bent either way.
Old 09-19-2003, 10:36 PM   #10
da-burb
"Ochre Ogre"
da-burb's Avatar
Personally, I don't think the guys working on the assembly line really cared what was bolted on. 2 of anything made a set. My 71 4x4 burb has factory hooks and there is a left and a right. I just looked at a 72 3/4 ton 4x4 last weekend in Iowa and it had 2 that hooked to the right. someone must not have liked that because it was heated and bent to the left and it didn't look good.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 09-19-2003, 10:41 PM   #11
da-burb
"Ochre Ogre"
da-burb's Avatar
Old 09-19-2003, 11:36 PM   #12
J.Lance
hooks
Finally got home to take a pic. Sounds like no one really knows for sure. Should we just say hooks are hooks? Matthew, I'm not concerned. I appreciate the offer to "make it right" but I'm satisfied. Thank you! I would like the look of opposing hooks better though so if anyone else has two of the same for '68, maybe we could trade one for one if we have opposites. If not, maybe I'll break out the torch down the road. Once again Matthew, thank you for the quick shipment and communication. As far as I'm concerned, based on the opinions presented, we have a good transaction!
Jason
1971 K2500 GMC LWB
Old 09-20-2003, 10:42 AM   #13
Rod
Mounting location
Old 09-20-2003, 02:02 PM   #14
BLAZERMAN
BLAZERMAN's Avatar
Rod, is that the correct mounting location? I thought the early hooks were mounted with the open end facing forward, it looks like the bumper would not fit back on in that pic.
Old 09-20-2003, 06:01 PM   #15
nu2-72
I have heard that this is the correct way to mount and it would make sense. Hooks should go down and out with the curl.
If you were in need of a tow, this would give the best position. As you were pulled forward and the towing chain hooked to the lower hook, the chain would ride up into the curl, preventing it from flying off.
Antone else?
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
