Old 01-06-2016, 11:12 AM   #1
bowt1ed
55.2 radiator support to fender
Hey guys, anyone got a good part number/supplier for the bushings that go between the radiator support mount and fenders (large holes)? Look to be similar to the inner fender mounting bushings, but I can't find on any site.
Thanks much, Jim
bowt1ed is offline   Reply With Quote
Old 01-06-2016, 01:31 PM   #2
Iceman_70
Iceman_70's Avatar
Re: 55.2 radiator support to fender
Hey Jim,
is this what you're looking for :
Description : Large rubber grommets for mounting inner fenders to cab and radiator support. Includes steel sleeve, as original. 4 piece set does both fenders.
I got them from Classic Parts : 37-851
'56 Chevy stepside shortbed
SBC350 - TH350
12-bolt rear
Iceman_70 is offline   Reply With Quote
Old 01-06-2016, 02:20 PM   #3
OrrieG
OrrieG's Avatar
That is what I used too, front is same as the cab bracket to inner fender. You need the flexibility because the frame and radiator support flexes as you go over driveway hump, ditches, logs, etc.
OrrieG is offline   Reply With Quote
Old 01-06-2016, 05:13 PM   #4
bowt1ed
Thanks guys. I have a set for the inner to cab, but didn't realize they were the same for the radiator support as well. Guess I better add to the wish list! Thanks again. Cheers, Jim
Old 01-06-2016, 05:42 PM   #5
OrrieG
OrrieG's Avatar
Classic has a "fender seal" kit with those and all other seals; fender to cab, fender to grille, inner fender to cab, etc.
Old 01-06-2016, 06:09 PM   #6
SideStepper
I am a little lost on this.
Are rods & bushings connected to the core support, going to the firewall? Where are they located?
Does anyone have pics of the entire factory support rod setup or maybe better yet a updated hotrod version that someone home engineered & fabricated in their garage?
SideStepper is offline   Reply With Quote
Old 01-06-2016, 08:24 PM   #7
_Ogre
_Ogre's Avatar
i have to admit... i'm a little lost on this too
i don't remember any rubber on the front end sheet metal other than the big blocks under the core support
and the little rubber isolators on the firewall to inner fender brackets
i realize the 55-57 may be different from 58-59, then orrieg chipped in with ''That is what I used too''
maybe my crs is kicking in?
shop air compressor timer
Old 01-07-2016, 12:59 AM   #8
OrrieG
OrrieG's Avatar
Here are photos of my 59 lower inner panel at firewall and near front. Think front is unique to 59-59 because of extended fenders and grille. The front does not show up in the FAM which does not have a 58-58 supplement in the main book you buy.
Old 01-07-2016, 12:26 PM   #9
_Ogre
_Ogre's Avatar
yeah, now i remember them
darned crs
Old 01-08-2016, 09:23 AM   #10
bowt1ed
Does anyone have a pic of how the 55-57 bushing locates at the radiator support to fender? I assume if it is the same type bushing it merely goes between the support and fender. I can't find a pic in FAM or LMC's, etc. parts breakdown diagrams. Thanks, Jim
Old 01-10-2016, 09:42 AM   #11
Roarinrat
Interesting thread....
I bought my 57GMC as pile of parts and I don't know how the top of the front fenders attaches to the radiator support. See pic illustrating the problem.
I can't see a way of bolting the top front of the fenders to the radiator support
I'd appreciate some advice or pics please.
Steve
Roarinrat is offline   Reply With Quote
Old 01-15-2016, 12:10 PM   #12
bowt1ed
As I recall, there is a hole/bolt that goes through at the very top. I'll try to get a pic when I return home next week.
