Old 01-06-2016, 01:07 PM   #1
AASmedic
AASmedic's Avatar
Adding Tachometer
Good day all. I am considering adding a "factory" tach to my dash cluster in a truck that didn't originally come with one. Correct me if I'm wrong but shouldn't I be able to purchase the tach, a harness and a new printed circuit board and install it in my current dash cluster?
AASmedic is offline   Reply With Quote
Old 01-06-2016, 01:14 PM   #2
Coley
Coley's Avatar
Re: Adding Tachometer
You're close and yes you need those items.
As well tho', you will need the alternate (tach based) inner and outer mount plates that will replace the 2 existing gauge mount plates that you have.
These alternate plates are stamped/cut out to allow for the tach mounting.
I think several companies including LMC (...yikes) makes complete kits that you can purchase to buy/install one of these....you will see these (2) alternate plates shown in their kits.
Or one of the board members like T-bone can set up nicely.
All Good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 01-06-2016, 01:22 PM   #3
AASmedic
AASmedic's Avatar
Thanks for the info. I have the opportunity to purchase a cluster with the factory tach in it for $300 but I am not sure that I need to spend that much if I can put one in mine for less. Opinions?
Old 01-06-2016, 01:31 PM   #4
flashed
$300 for a Tach Dash is a deal if it works .
flashed is offline   Reply With Quote
Old 01-06-2016, 01:37 PM   #5
TBONE1964
Cluster King
TBONE1964's Avatar
It depends on what you want. You can modify your existing cluster to accommodate a tach but I do not recommend it.
Be careful buying used OE tach clusters. If you can get the seller to back up that the tach will work, that would be the only way to buy one. If you have a factory tach cluster with a bad tach and a bad circuit board, all you have left of value is the tins.
I only use aftermarket parts now unless my customer supplies parts.
If you were to start from scratch, you would be looking at around $550.00 for a nice restored like new tach cluster.
If you need my help in the future, please let me know.
Take care,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 01-06-2016, 01:46 PM   #6
AASmedic
AASmedic's Avatar
Thanks Tom. I will take any advice I can get. I have a 72 K20 numbers matching truck with 88k original miles. The motor is solid but I would like to update things such as adding tach and tilt. Other than that some cosmetic stuff is all it needs. I have an "empty" dash bezel that I can install my gauges in. Is that something you would do or just pick up the one for $300 and restore it?
Old 01-06-2016, 01:58 PM   #7
TBONE1964
Cluster King
TBONE1964's Avatar
If you can get the seller to back up the tach working, then I would say $300.00 is a sweet deal even if you have to put a new aftermarket circuit board in it.
The aftermarket tachs are around $100.00, so if you need to replace it, you now have a $400.00 cluster that still needs restored.
Hope this helps. Myself, I would much rather have a factory tach cluster than just having a tach clamped to my steering column.
Hope this helps.
Take care,
Tom
Old 01-06-2016, 02:00 PM   #8
AASmedic
AASmedic's Avatar
Ok, he says it works but no guarantees because he is parting out old trucks. You buy it as is.
Old 01-06-2016, 02:11 PM   #9
davepl
davepl's Avatar
I don't think anyone said it, but you need the lens as well if you'd like numbers on your tach scale I'd think...
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-06-2016, 02:20 PM   #10
AASmedic
AASmedic's Avatar
Good point. I'm considering just going with the LMC kit. Opinions?
Old 01-06-2016, 02:57 PM   #11
1972RedNeck
1972RedNeck's Avatar
LMC doesn't make much of anything. They just buy the parts and mark them up. I would see if a board vendor like Classic Heartbeat could set you up.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 01-06-2016, 04:17 PM   #12
flashed
I would let Tom set one up ,he does nice work.
Old 01-07-2016, 12:14 AM   #13
AASmedic
AASmedic's Avatar
Thanks for the advice flashed. I will PM Tom about it.
Old 01-07-2016, 03:39 PM   #14
Tdrcreyn4
Tdrcreyn4's Avatar
Tom built one for me too and it's outstanding! Excellent work!
1968 C10 292/3 spd - sold
1969 K10 350/3 spd/205 - sold
1971 K5 350/4 spd/ 205 - sold
1970 K20 350/350/205 - sold
1969 K20 396/400/205 - work in process
Tdrcreyn4 is offline   Reply With Quote
