Old 01-06-2016, 04:48 PM   #1
Voodoo556
Voodoo556's Avatar
Rut Row, that doesn't look good!
So the PO of the '70 k20 I picked up last weekend had told me it had a starter issue. He said it needed to be shimmed. Well, it needs to be shimmed alright lol.
There is a chunk of the engine block casting that is missing. I'm assuming it is possible that was caused from him over tightening the bolts. Maybe with an impact or a 3ft cheater bar!
The bolt still tightens but I'm struggling to get the starter dialed in/lined up so it does not bind, screech or drag. I definitely do not want this to be an on going problem.
I'm thinking I might be able to get her shimmed correctly, add a rear support brace to block and then add some blue never seize.
So, what to do.
Options:
Attempt to shim and never seize.
Yank the motor and attempt to "fix"
Yank motor and replace with another short block or complete motor
Yank and replace with big block
Any thoughts fellas?
Voodoo556 is offline   Reply With Quote
Old 01-06-2016, 04:51 PM   #2
The Chainsaw
The Chainsaw's Avatar
Re: Rut Row, that doesn't look good!
Small broken piece? Definitely replace with the big block
Not making fun, it's what I would do. Although I might have a problem.
The Chainsaw is offline   Reply With Quote
Old 01-06-2016, 05:07 PM   #3
Voodoo556
Voodoo556's Avatar
Yeah there is a small piece that is broken off, not just a crack.
Simplest would be to toss another small block in but damn, I'm torn.....fighting the demons of a big block.
Old 01-06-2016, 05:17 PM   #4
dazza
dazza's Avatar
he must have had one of his 'chiks' torque'n on that thing!
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
Old 01-06-2016, 05:19 PM   #5
Voodoo556
Voodoo556's Avatar
Well odds are it was probably a purdy dang healthy gal!
Old 01-06-2016, 05:32 PM   #6
MARKDTN
Could you use a mini-starter and the other set of holes?
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 01-06-2016, 05:56 PM   #7
Voodoo556
Voodoo556's Avatar
I bought a high torque mini starter but it uses the same hole as the Orig starter
Old 01-06-2016, 06:07 PM   #8
michael bustamante
michael bustamante's Avatar
yup id find the starter brace and never seize too til i found a built up 454!!
1967custom
michael bustamante is offline   Reply With Quote
Old 01-06-2016, 06:10 PM   #9
Voodoo556
Voodoo556's Avatar
I think that's a good choice. I don't really want to yank the motor just because of the starter and the chunk out of the casting. I'd like to fix it and then I can start a build on a bb or a nice sb.
Old 01-06-2016, 07:08 PM   #10
trac209
I had this happen long ago and I fixed it by jb welding a stud it there and using a nut to tighten starter
trac209 is offline   Reply With Quote
Old 01-06-2016, 10:06 PM   #11
Mike C
Mike C's Avatar
Yup, try and drill hole deeper and tap for a stud. Locktight in there and pray.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-06-2016, 10:45 PM   #12
El Dorado Jim
I would go with the stud and jb weld fix if it was me
El Dorado Jim is offline   Reply With Quote
Old 01-06-2016, 10:56 PM   #13
72ironmike
72ironmike's Avatar
Can the block be ground even to allow room for a very thick washer or sleeve ?
72ironmike is offline   Reply With Quote
Old 01-06-2016, 11:38 PM   #14
dazza
dazza's Avatar
just always park on hill and keep one of the po's chiks in the back... bump starts made easy...
but better yet, you could try one of these... adapter
Old 01-07-2016, 12:38 AM   #15
Voodoo556
Voodoo556's Avatar
I was looking at this adapter this afternoon, I think that's the ticket right there. Done, problem solved.
Old 01-07-2016, 02:03 AM   #16
57taskforce
All about them K’s
57taskforce's Avatar
I'd bet on that starter bolt backing out a bit first then somebody cranked it over with the bolt loose and broke the block and probably the bolt too. I've seen it happen before. As for fixing it, either the adapter or stud would probably work pretty good.
Tyler
57taskforce is online now   Reply With Quote
Old 01-07-2016, 07:47 AM   #17
hamjet
hamjet's Avatar
Is the adapter for 153 or 168 tooth flywheel? or either. whats yours?
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 01-07-2016, 10:25 AM   #18
bill3rail
bill3rail's Avatar
Sounds amazingly simple, and I would do it if needed.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 01-07-2016, 10:30 AM   #19
72kool
72kool's Avatar
with it broken like that, the only option i see is a big block. sorry to deliver you this terrible news.
72kool is offline   Reply With Quote
Old 01-07-2016, 11:52 AM   #20
Cajun
I had this same problem on my drag car motor. Since I already had the SBC parts replacing with a BBC just wasn't in the budget. I was able to find a machine shop who was the only one in the city that had the right material to match the block composition. I did have to pull the motor and strip it down for him since he put the block in a jig and added new material to the broken tab and filled it in completely and then drilled and tapped the hole for the bolt. This was a 14.1 compression motor with a mini gear reduction starter. Never had a problem for the 10 years I had it. Of course the BBC would have been nice too.
Cajun is offline   Reply With Quote
Old 01-07-2016, 12:25 PM   #21
Jason Banks
Jason Banks's Avatar
I also had this happen to a 350...I had someone come out and use some special welding rods for cast iron and weld some material on that I then tapped out for a bolt.
It was a major pain...but the guy welded it with the engine still installed.
A few months after it was fixed the motor self destructed....so I don't know how well it worked long term.
I like the JB weld and a stud idea!
Jason Banks is offline   Reply With Quote
Old 01-07-2016, 02:15 PM   #22
MARKDTN
I would be careful of a stud. There is a reason that the starter bolts are knurled as they are. If you don't use correct bolts it can get misaligned. Studs may cause the same issue. On a standard trans, can't you use a 6cyl bellhousing and put the starter on the bellhousing instead of the block?
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 01-07-2016, 02:55 PM   #23
zeldman
zeldman's Avatar
Very true.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
Old 01-07-2016, 05:50 PM   #24
Voodoo556
Voodoo556's Avatar
I am leaning towards going with the bell housing mounted starter.
Seems to be the most solid, although it involves pulling the motor and trans apart, long term solution.
http://www.crankshaftcoalition.com/w...lock_is_broken
