01-06-2016, 08:28 PM | #1 |
1962 chassis with 1966 sheet metal
Hello,
I understand the differences in the frame rails, front suspension and X member, but will the cab, fenders, bed and bumpers of a 66 fit on a 62 torsion bar frame? |
01-06-2016, 10:06 PM | #2 |
Re: 1962 chassis with 1966 sheet metal
There is alot of good info in the FAQ section. If I remember right the bumper mounting maybe different?
01-06-2016, 10:15 PM | #3 |
I believe they have different front cab mounts. Also the bumpers will fit but the holes won't line up. If you really wanted to make the later bumpers work on the early frame you could weld the old holes shut and drill new ones then use a file to make them square.
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
01-06-2016, 10:20 PM | #4 | |
bumpers.cab and box mounting are different and the frame nbrs will not match the cab vin nbr so you will have that to deal with. there is also you will have a problem installing manual clutch linkage as 60-62 used hydr. linkage mounted on passenger side ron |
01-07-2016, 12:05 AM | #5 |
It was just a thought. Not a very good one. Too many differences
01-07-2016, 01:48 AM | #6 |
60-66 Nut
In the state of Idaho, having a frame and cab with different VIN's can be an issue unless you follow the state motor vehicle investigator's requirements. That can be both expensive and a pain in the butt.
