01-06-2016, 10:41 PM | #1 |
Rear main seal 292
I'm driving a 1970 292 and my rear main seal starting leaking recently and I'm looking to replace soon. I've dropped my oil pan before and it is a pain in the rear having to lift the motor. Does anyone have any advice on if I can get the rear main changed by removing the oil pan bolts but not lifting the motor to fully remove the pan. Thank you
1972 292 c10 |
01-06-2016, 11:38 PM | #2 |
Re: Rear main seal 292
you will never get the pan off without lifting the motor pain in the ***
01-07-2016, 01:13 AM | #3 |
Would I at least be able to lower it enough to have the clearance to get in there and pull the seal out
01-07-2016, 03:11 AM | #4 |
BTDT. You will have to loosen motor mounts and even free up one side, and jack up rear of block to get oil pan out for regasketing.
Yes it's a PIA.
01-07-2016, 07:33 AM | #5 |
For the amount of time you will spend laying on your back cursing ,cleaning the old gaskets off and replacing them it's just easier to spend a weekend and pull it out ,Change ALL the gaskets ,clean,repaint and reinstall and not take the chance of it leaking again .Sometimes it just pays to bite the bullet and GIT ER DONE
01-07-2016, 12:38 PM | #6 |
^^^^^^^^^^ yea what he said I'm going to have to do it to mine it's leaking at the front...
1964 BBC 402 4x4 |
01-07-2016, 03:11 PM | #7 | |
Get a couple friends, fire up the grill, stock up on favorite beverages and make a weekend out of it.
2005 GMC K2500HD D/A 1993 GMC K1500 2011 Subaru Legacy. 2013 Subaru Outback 1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot. |
01-07-2016, 06:30 PM | #8 |
x3 on Grumpy's post. You are far better off pulling the engine & replacing all the gaskets, seals, AND freeze plugs.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
