Old 01-07-2016, 03:32 AM   #1
Ezzz
Can't find correct length rear shocks
Hey guys, got a 69 C10 with a coil rear end dropped 4/6. I'm running the hotchkis springs which have a pretty light spring rate in the rear. Rear shocks were at a pretty nasty angle so did lakeroadsters rear upper shock relocater which I'm happy with angle wise. I've attached his link so you can see what I'm working with and in case it helps anyone else out. Easy, well thought out, and works. Thanks lakeroadster
http://67-72chevytrucks.com/vboard/s...d.php?t=451200
Now it's time to find some new shocks since the old ones are seized (probably from the angle they were run at) and the incorrect length. I've looked up how to measure and I get 9" compressed, 13" static, and damn near 18" with the wheel just barely touching the ground extended. The po did some funky stuff but don't think he did a long travel rear end. Nonetheless I'm having some trouble finding a shock that meets those lengths or anything close.
The truck was lowered 7.5 out back so I notched it. I figure I can limit the downward travel with a bigger bumpstop but the notch was a pia and I'd hate for it to be for nothing. And while I don't plan on necessarily jumping the truck, I do want to beat on it, and don't know if using the shock as a suspension limiter is the best idea.
I've been looking through manf. pdfs at lengths and I'm lost. I know I'm not gunna find a shock that's 9" compressed with a 9" stroke but if you guys can point me in the right direction it'd be greatly appreciated.
Ezzz is offline   Reply With Quote
Old 01-07-2016, 08:00 AM   #2
PGSigns
PGSigns's Avatar
Re: Can't find correct length rear shocks
You cant go by the length with the rear hanging with out the shocks as the shocks a lot of times is what is holding the rear end when you jack one up. I would take your 13" static and ad 3 inches of travel and look for a shock.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-07-2016, 11:12 AM   #3
SCOTI
SCOTI's Avatar
That's about the dimensions of a front shock for your truck.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-07-2016, 12:25 PM   #4
slotard
You notched it enough that you have 4" of uptravel? That's more than I'd have expected.
I agree that you won't be able to get that much droop either. If you look at a single telescoping shock with ends for attaching to something, you can't have extended length double compressed length. I think a couple inches of downtravel would easily be adequate.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 01-08-2016, 04:20 AM   #5
Ezzz
SCOTI that made me check out front lengths and summit has some edelbrock ias's for just $20. Think at that price I'm gunna go for it. Just wondering if shocks at that price point are valved or tuned differently for front and rear? Guessing if they are they'd be way to firm. Or is it likely the same shock in a different length?
Old 01-08-2016, 10:30 AM   #6
SCOTI
SCOTI's Avatar
I agree on the valving concern when utilizing front shocks in a rear application but I know guys have done it. Me personally? I always try to stick w/the correct shocks & move the mounts as needed to get them to work. If I can't tweak the mount locations, I'll seek out the closest possible application w/the correct shock ends & length required (I used Monte Carlo SS/g-body shocks for the rear of my 90).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
