Anyone using the 4.3L V6 in a 47-54
is anyone using the 4.3L V6 with the S10 swap in a 47-54 pickup? looking for a picture or two to see how small that thing will look in there. did you have to move the mounts at all?
![]() Join Date: May 2007
Re: Anyone using the 4.3L V6 in a 47-54
this is moved back 5 inches on a 47, doing it again on a 49 and moving it 7 inches so the s10 clutch fan will fit this time
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
when moving it back 7 inches, how much goes into the fire wall? did you have to fab your motor mounts? sorry for all the questions, but i got a hold of a 86 4.3L 4bc quadrajet with only 23k miles on it, and i want to make it work.
7 inches wont hit the firewall at all. we made mounts like v8 swap mounts that slid the factory clamshell mounts back 5 inches.
Cool , that will work for me. thanks
I moved mine back 5" and still had plenty of room for the original fan. the only difference is that I slanted my 'stock' radiator forward at the bottom to clear the S10 steering box.
Looks good, i think i will go 5" back but use electric fans on the radiator to free up some hp on the engine.
are these the mounts that you used?
me? no. we made ours
I just cut off the original mounts and welded them back on 5" farther back and then filled in the gaps with scrap metal.
