Old 01-07-2016, 01:04 PM   #1
gable74
gable74's Avatar
Fuel Tank / Aux tank(s) question
Is it safe to say that I could tie my two saddle tanks together and use them as one tank since they sit at the same level in the truck? I am considering going with an electric tank selector that would switch tanks and switch fuel sending units at the same time but they only make them for dual tanks, nothing for three tanks.
1972 K-20 Custom Camper
1971 K2500 Custom Camper (Sold)
2014 GMC 2500HD DMAX
gable74 is offline   Reply With Quote
Old 01-08-2016, 07:25 PM   #2
motorcritter
motorcritter's Avatar
Re: Fuel Tank / Aux tank(s) question
Your running the in-can tank, plus two sidesaddle tanks, I'm assuming. Linking the side tanks to a common outlet, running the stock tank into your switching setup should work, but only one side tank level gauge would be needed. A pretty robust side tank link pipe would help keep the tanks fuel levels constant. Treat the side tanks like one tank, the stock one like the second.
motorcritter is offline   Reply With Quote
Old 01-08-2016, 07:54 PM   #3
davepl
davepl's Avatar
Can you tie them together at a low enough point to be useful and still be safe though? Fuel doesn't flow uphill, so the line needs to be the lowest part of the tank (or it'll be the lowest point at which the two tanks will exchange fuel, anyway).
I worry that having a line come out of the bottom of one tank and into the bottom of the other would be so low that it'd be hard to route safely. But I can't read your mind or see the tanks, so just throwing it out there.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-08-2016, 09:21 PM   #4
jeffahart
jeffahart's Avatar
Those old saddles don't have sending units. Engine sputter is the gauge, plus a little horse sense on when you filled and how long you've drove on the particular running tank. Just keep them isolated. I drove thousand of miles with my old saddles back in the 80s. Just reach down and flip the fuel petcock when the engine starts to sputter. I recently ditched my old saddles. Had mixed feeling about them for my usage now days.
White K20
jeffahart is offline   Reply With Quote
Old 01-08-2016, 10:07 PM   #5
mtdave2
newly minted old timer
mtdave2's Avatar
Well my aux tank has a fuel sending unit in it, and it is orginal..
The two tank thing, I would just tie the outlet hoses together and run to an electric tank selector, one for main one for aux tanks.
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 01-08-2016, 10:08 PM   #6
DeadheadNM
Carpe manana
DeadheadNM's Avatar
What's your goal in tying the tanks together in a manner that's different from the current arrangement? My 72 GMC has OEM sending units for the dual aftermarket tanks (Travel Tanks) with a toggle switch to select the sending unit for either aux tank or the factory tank (fwiw pic here: http://67-72chevytrucks.com/vboard/s...48&postcount=3). A floor mounted selector allows you to manually select gas flow from your tank of choice.
Old 01-08-2016, 10:13 PM   #7
jocko
jocko's Avatar
Like mentioned above, some saddles had senders, some didn't. All NL2s had senders. I think I'd avoid tying them together - like Pete, I'm not sure how it's any less work, unless you had a single damaged inlet on the tank selection valve (in which case I'd really want to replace it anyway). Seems if your answer is "it should work" and there's no more work in doing it the original way - I'd go with original because we know it works. Personally, I'd prefer to switch at the valve and have the pump drawing fully from ONLY the tank I've selected rather than two that feed into it. Again, I agree it should work, just don't see what there is to gain by linking them before the valve - unless perhaps the goal is just to avoid one additional flip of the switch.
Old 01-08-2016, 10:24 PM   #8
89AKurt
89AKurt's Avatar
I removed the saddle tanks off my truck, if anyone in Arizona wants cheap tanks, let me know.
1968 C-10 Long Bed Blue Cloud
1956 GMC 100 GYMEE
1969 Corvette that identifies as a Ferrari Daytona Spyder Fakerri
2016 Honda Civic EX-T Stealth
89AKurt is offline   Reply With Quote
Old 01-08-2016, 10:30 PM   #9
jocko
jocko's Avatar
If I still lived there, I'd be on my way... Bedside or wheelwell filler neck?
Old 01-08-2016, 11:17 PM   #10
89AKurt
89AKurt's Avatar
Wheelwell.
1956 GMC 100 GYMEE
Old 01-08-2016, 11:42 PM   #11
jocko
jocko's Avatar
those are the BEST! Someone's gotta come grab those. Holy cow.
Old 01-09-2016, 01:42 AM   #12
gable74
gable74's Avatar
I guess my only real reason was because I'm lazy... What I wanted was the convenience (or the simplicity) of flipping one switch that would control both the tank selection as well as the sending units. Yes, both of my aux tanks have sending units. I have the valve on the floor as well as this switch on the dash that selects the proper sending unit. The green switch controls the cruise control and has nothing to do with the fuel tanks. Just gauging the thoughts of those who certainly have more experience on the matter than I do. Thanks for the input!
