![]() Join Date: Jan 2011
Question On Notches for Bed Wood
OK guys, I need the measurements for the notches that are cut into the two short boards that fit into the bedside corners (fleet side).
Or, are these cut-to-fit for each bed? Thanks, POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
Re: Question On Notches for Bed Wood
I would cut to fit, I cut enough out the boards to clear the tires, installed & marked ,then cut. Why screw it up by using someone else's specs? I would also leave the center two boards till the rest are installed in case you need to adjust their width.
lol didn't look at pic. Those I measured to fit but removed as little material as possible on the first cut and installed and adjusted as necessary by removing a little each time. |
If memory serves it was approximately 2" square.
| Bookmarks |
