Old 01-07-2016, 04:56 PM   #1
Hart_Rod
Hart_Rod's Avatar
Question Porterbuilt air line routing....
I'm looking for some good pictures/suggestions for front air line routing for my Porterbuilt extreme dropmember. What ya got?!?! TIA.
Hart_Rod is offline   Reply With Quote
Old 01-09-2016, 08:36 PM   #2
Rochlow
Re: Porterbuilt air line routing....
I ran mine on the outside of the frame rail held down with insulated line clamps. Went behind the and under shock. I drilled a hole in the rear upper spring mount and used a 90 degree fitting
///Relaxed Atmosphere
Rochlow is offline   Reply With Quote
Old 01-10-2016, 09:05 AM   #3
dec010974
dec010974's Avatar
Hey Hart_Rod. I've read your threads several times and stole a lot of your ideas. You were one of my inspirations to bag my c10. Do you really wanna take a chance and get ideas from a novice like me, really? That's like a 40 year old oak tree asking a pallet of grass how to grow. I used insulated wire clamps and routed them along the frame rail up to the bags. When the air line entered the stock crossmember, I routed the air line thru some heater hose. Good luck and thanks for all your ideas and inspiation. Happy New Year.
dec010974 is offline   Reply With Quote
Old 01-10-2016, 12:52 PM   #4
Woodnears
I'm gonna follow this thread for inspiration but I will say I have been using stainless steel line clamps for all lines and wiring. I have a roll of aluminum line in he garage just waiting for me to grow a set to bend it. I currently have dot line and I just don't like how it bends around certain areas.
Woodnears is offline   Reply With Quote
Old 01-10-2016, 08:21 PM   #5
cshetsky601
cshetsky601's Avatar
I ran all my 3/8" line with made4you clamps. I routed the airline,fuel line, as well as the brake line in them. They have various sizes where you could have 2 different sizes in one clamp.
1967 Body Dropped C-10
454 Big Block/TH400
Porterbuilt Extreme Front & Rear Dropmembers
22/24 Raceline Hooligans
cshetsky601 is offline   Reply With Quote
Old 01-11-2016, 10:45 PM   #6
Longhornss
I like this setup it is very clean.
I especially like the bulkhead in the frame close to the air tank I was just telling my brother I want to do the same thing to try and keep everything clean.
Longhornss is offline   Reply With Quote
Old 01-12-2016, 10:11 PM   #7
cshetsky601
Thanks Longhornss. I tried to keep it as clean as possible and still be able to work on it easily.
454 Big Block/TH400
Old 01-19-2016, 12:46 PM   #8
Hart_Rod
Hart_Rod's Avatar
Sorry for the late response, I've been dealing with a family pet emergency. Thanks for the posts and pics. What I'm specifically looking for is how you brought the airline from inside the frame to the front airbag fitting. As I see it, there's know "elegant" way to do it....
Old 01-20-2016, 09:45 PM   #9
cshetsky601
I actually ran my 3/8" line through the hole that is through the frame and upper bag mount. It was kind of a pain to do ended up running some chafing material around the airline going through the frame until I'm able to get a rubber grommet for it. I don't have any pictures right now of how I did it but could get some in a few weeks once I make it back home if you still need it.
454 Big Block/TH400
Old 01-21-2016, 09:18 AM   #10
panhandler62
Java Mechanic
panhandler62's Avatar
On a side note; I love the "double" tailgate mod to finish the raised bed. That looks really cool.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 01-21-2016, 09:55 AM   #11
Hart_Rod
Hart_Rod's Avatar
Pics would be great!
Thanks!
Old 02-22-2016, 01:21 PM   #12
Hart_Rod
Hart_Rod's Avatar
Here's what I ended up doing....
Old 02-22-2016, 05:42 PM   #13
LowLifeS10
LowLifeS10's Avatar
Kinda late to the party but this is how I did my lines. + a 90 elbow fitting.
GMC C15 -68 project: http://67-72chevytrucks.com/vboard/s...d.php?t=526059
Front/back Porterbuilt dropmember, Accuair, LS1/4L60e
Chevrolet C20 -72 C20 to K10/20 conversion, LS power.
LowLifeS10 is offline   Reply With Quote
Old 02-23-2016, 10:34 AM   #14
Hart_Rod
Hart_Rod's Avatar
Thanks!
Old 01-29-2017, 12:28 AM   #15
youngrodder
youngrodder's Avatar
I'm curious to know more details about your clamp on the upper PB A-arm holding the brake line. Where did you get it?
Looks great.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-29-2017, 08:43 AM   #16
Hart_Rod
Hart_Rod's Avatar
Looks great.
Marc
McMaster's
Old 01-29-2017, 11:18 PM   #17
youngrodder
McMaster's
That's what I thought....I also seem to remember seeing some somewhere that were black with a small hole to run the hose through. Kind of looked like some hose clamps from billet specialties but I don't recall where I saw them.
Thanks for the reply
Marc
