Old 01-07-2016, 05:15 PM   #1
BigSix
Firewall electrical plug pin-out diagram?
I need some info on what the wires to the firewall plugs are doing.
The large connector by the brake master melted on mine so I am just going to run the wires through a grommet.
Also looking to sub in a blade fuse block - so any information on which one would be awesome.
I didn't find anything in a search but if this has been covered so sorry - just let me know where.
BigSix is offline   Reply With Quote
Old 01-07-2016, 05:26 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Firewall electrical plug pin-out diagram?
You should be able to use this:
Old 01-07-2016, 08:39 PM   #3
DPowers
DPowers's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=378484
DPowers is offline   Reply With Quote
Old 01-08-2016, 07:34 AM   #4
PGSigns
PGSigns's Avatar
If the harness is that bad and you want a new fuse block I would put a new harness in the truck. I did it in my 65 after trying to fix what I had to no avail. Every time I went to work on the truck something else would not work. I went with american auto wire in mine and would highly recommend them.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-08-2016, 12:22 PM   #5
BigSix
Jimmy
Inside the cab the harness is like new. Under the hood the harness is fine but I pulled the stock V6 and put a diesel in there. Along with the swap came different alternator/regulator setup. So really I should say that I am rewiring under the hood.
If I wanted to keep the large firewall connector that is by master cylinder would there be a source for a replacement?
Old 01-08-2016, 05:47 PM   #6
ray_mcavoy
Those are Packard/Delphi 56 series connectors. New terminals for them are readily available from a number of sources (including many local auto parts stores). However, the plastic connector shells used in this location are somewhat specialized. And I don't think replacements are readily available (at least not without buying them as part of a new reproduction harness).
So the only other option would be to find a junk harness that still has those connectors intact. Extract the old terminals/wires, clean up the plastic connector shells, crimp new terminals onto your wires, and insert them into the appropriate cavities.
ray_mcavoy is offline   Reply With Quote
Old 01-09-2016, 06:56 AM   #7
The Rocknrod
Moderator
...If I wanted to keep the large firewall connector that is by master cylinder would there be a source for a replacement?
American Auto Wire has them. Here they are on ebay:
http://www.ebay.com/itm/391131380023...%3AMEBIDX%3AIT
Old 01-09-2016, 07:21 AM   #8
mark 66
just went thru what pg signs did. highly recommend buying new harness.just got it from mcb matt. good price high quality.
mark 66 is offline   Reply With Quote
Old 01-09-2016, 07:34 AM   #9
The Rocknrod
Moderator
Does the American Autowire kit come with the firewall connector like ours? What is the kit number?
Old 01-10-2016, 08:15 PM   #10
BigSix
Thanks guys - so I checked the harness I have and its actually great. Really good.
So here is the next issue: since I no longer need the voltage regulator, or anything distributor/coil related, what do I hook up to get 12V to the harness. Can I run the 12V Red wire direct from the battery to the wirewall connector instead of to the horn relay first? My 1 wire alternator doesn't need to sample from the horn relay so I figure it would make most sense to send 12V straight through the red wire to the firewall connector on the driver side near the master?
