Old 01-07-2016, 06:37 PM   #1
DENALI
Anyone use a 47-54 Speedway bolt in Mustang IFS?
I am looking to get an idea of how the finished truck sits when all is said and done? I am wanting to pretty low stance. Planning to go static rather than bags. Thanks
DENALI is offline   Reply With Quote
Old 01-15-2016, 08:42 PM   #2
jetnow1
Re: Anyone use a 47-54 Speedway bolt in Mustang IFS?
Why would it set any different than a weld in setup- the way the frame sits against the
crossmember would be the same height wouldn't it? There are also dropped spindles
available if you want to go lower.
jetnow1 is offline   Reply With Quote
Old 01-15-2016, 11:16 PM   #3
DENALI
According to speedway the bolt in cross member is not compatible with airbags so to answer your question it can only go so low compared to an airbag capable cross member.
Old 01-16-2016, 12:41 AM   #4
northern 49
northern 49's Avatar
Hey there, I'm new here but it thought I would share what I have done to my 49. It has a speedway bolt in crossmember but Is no where near finished but the cross member was an easy install and from what I understand it should sit about six inches lower than stock with drop spindles. Hopefully my picture uploads. Like I said new at this.
northern 49 is offline   Reply With Quote
Old 01-17-2016, 04:09 AM   #5
joedoh
joedoh's Avatar
hey welcome and great first post! start a project thread if you think about it, I would read it
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
