Old 01-07-2016, 08:18 PM   #1
Nodnarb76
Nodnarb76's Avatar
brake booster nipple removal.
Got my motor in today, and when looking over the motor, looks like I will need to install the nipple into the rear of the intake for my brake booster.
I happen to work for a dealership and we actually had an old intake manifold for my motor laying around.
I could not figure out how to remove the nipple from the manifold. I can't pull it out and it won't unscrew. Any Ideas?
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 01-07-2016, 08:38 PM   #2
First c10
First c10's Avatar
Re: brake booster nipple removal.
Push in the on whole nipple and red collar. Hold the red collar in and the nipple should pull out.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 01-07-2016, 10:16 PM   #3
Nodnarb76
Nodnarb76's Avatar
Ok now the dumb question.... Push in on the red collar toward the manifold right?
Sorry manifold is at work and I'm home now so it's not in front me to fiddle with. Seems like I tried all sorts of combinations trying to remove it, just wanting to make sure I'm pushing in the right direction.
Again sorry for the dumb question and thanks for the help!
Old 01-07-2016, 10:18 PM   #4
First c10
First c10's Avatar
In the current picture you need to push in on the red collet toward the manifold and the nipple should slide out nice and easy.
GO GO!!!
Old 01-07-2016, 10:21 PM   #5
First c10
First c10's Avatar
Like this.
GO GO!!!
Old 01-08-2016, 12:48 AM   #6
Nodnarb76
Nodnarb76's Avatar
Awesome thank you now I get it.
Will try as soon as I get to work tomorrow.
Old 01-08-2016, 01:17 AM   #7
truckdude239
truckdude239's Avatar
Is there any numbers on the plug you have? Alot of us have been trying to find thT plug i just have mine caped off
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-08-2016, 02:18 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Truckdude are you looking for the actual vacuum nipple piece? (what he shows in the pic).
or are you looking for a factory part to block that port off?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-08-2016, 07:22 AM   #9
LeesTruk
TruckDude, the 5.3l for my swap, came from a Tahoe with hydraboost, and had the plug in the plenum. I removed the plug for a vacuum nipple. If you need a plug, you can have mine (I saved it). PM me if you want it
Lee
LeesTruk is offline   Reply With Quote
Old 01-08-2016, 08:52 AM   #10
Nodnarb76
Nodnarb76's Avatar
Thanks again guys. I got to work this morning and it came right off. Thank you again.
Old 01-08-2016, 09:14 AM   #11
solidaxel
solidaxel's Avatar
Removing that plug was the first TRICK the folks on here taught me about L S engines!!
The fuel lines was the second one, but I needed a tool
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-08-2016, 02:52 PM   #12
First c10
First c10's Avatar
Glad it worked out.
Guys I removed the nipple and installed a tee 1 vacuum line to the booster and another one to the AC canister
GO GO!!!
Old 01-08-2016, 09:36 PM   #13
truckdude239
Been trying to find the factory plug i have manual brakes. I have mine caped off with a rubber cap and hose clamp and ive replaced it twice already cause the one the parts stores sell keep dry rotting and leaking.
I had my dealer try to find the part numer but they had no luck
David fuller
2000 Tahoe 5.3l 378
Old 01-09-2016, 12:24 AM   #14
ls1nova71
ls1nova71's Avatar
I have never found a GM part number for the plug and i have been looking for years. In this thread is some info on what will also work. Post #6 http://ls1tech.com/forums/conversion...l#post18528131
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-22-2016, 02:14 PM   #15
truckdude239
https://m.mscdirect.com/mobileweb/pr...tedParts=false
Found this
David fuller
2000 Tahoe 5.3l 378
