Old 01-07-2016, 09:29 PM   #1
Tod59
Stuck Speedometer?
Hey Fella's,
Problem:
My speedometer on my 59 is stuck (see picture).
Symptoms:
It has a speedo cable in it, I removed the cable from the speedo assembly and the cable looks fine. I even sprayed a small amount of lube in the speedo hole, but no help. The cable had grease on it that was dark and stuck to my fingers upon inspection.
The speedo needle does move if you are going faster than about 30 mph.....but it only moves as the speed increases and will not go back to zero or below what it shows. since I didn't drive faster than 50, not sure if speedometer was just bouncing or actually moving....hard to tell.
I just got the truck a few months ago, so not sure where to start. Any ideas?
Tod
Tod59 is offline   Reply With Quote
Old 01-07-2016, 10:01 PM   #2
mr48chev
mr48chev's Avatar
Re: Stuck Speedometer?
Spraying lube in that hole isn't going to do anything as it's a blind hole. First off I'd pull the cable out of the housing and wipe it off and then lube it with white lubriplate and put it back in. Just some on your fingers on one hand as you slide it in with the other hand will work you don't have to over do it. Then you can pretty well figure that the cable isn't binding up.
I've taken some apart and cleaned them up and put a tiny bit of lube like sewing machine oil on the parts and put them back together but they are a bit delicate.
You might check your local directory for speedometer repair as most areas have a shop within a reasonable distance that repairs speedometers and or calibrates speedometers. http://www.yellowpages.com/mi/speedometer-repair
My ongoing truck projects:
Old 01-07-2016, 11:21 PM   #3
Janky59
Janky59's Avatar
Looks like time for repair/service. I sent mine off to AutoInstruments, Martinsville, VA for service, calibration. Old lube/grease probably has the works gummed up.
2018 BMW R1200RT
2013 Aprilia Tuono
2012 Ford Flex
2011 Ducati Hypermotard
1959 Chevy 3100
Janky59 is offline   Reply With Quote
Old 01-07-2016, 11:44 PM   #4
Tod59
Thanks guys.
Old 01-08-2016, 11:22 AM   #5
58CameoAZ
I had the same thing happen to my 58 back in the day,and i ended up rebuilding the whole
unit by taking it apart and freeing up and cleaning it and using sewing machine oil like
Mr48 said. i was able to get mine to free up by cleaning the dust and gunk out of it
but it is a kinda delicate job and you are working with small screws and components.
I have seen were you can zero it back with tape on numbers that some of the vendors
have,not sure how well they stay on tho. But i was able to get mine to free up!
Good luck,
Allen
58CameoAZ is offline   Reply With Quote
Old 01-08-2016, 04:37 PM   #6
_Ogre
_Ogre's Avatar
sadly i've had my speedo out more times than i care to say
a speedo works or it doesn't, yours is just hanging up
typically if the speed hangs, the needle is stuck on the face plate or the back
it doesn't take much to make them stick
pulling the speedo isn't terribly hard once the cluster is out, pulling the cluster is the hard part
there are 4 screws that hold the speedo in and it comes out in one piece
you can operate the speedo with a cordless drill to check it once you have adjusted the needle
pulling the odometer out to reset it to reflect the total rebuild of my truk
it's not illegal unless you try to pass it off at the lower mileage
usually there is a age that the dmv doesn't care what mileage your classic vehicle has
shop air compressor timer
Old 01-08-2016, 04:38 PM   #7
_Ogre
_Ogre's Avatar
pulling the cluster is a good time to change all the light bulbs in the cluster too
Old 01-08-2016, 05:51 PM   #8
1project2many
Ogre, why haven't you replaced all those spade terminals with a nice, single connector?
1project2many is offline   Reply With Quote
Old 01-08-2016, 06:34 PM   #9
_Ogre
_Ogre's Avatar
(insert eye roll here)
didn't have one available when i did it
it works as is, no need to change it now
Old 01-08-2016, 06:59 PM   #10
58CameoAZ
Ogre,You mention changing light bulbs in the cluster,I bought a new wiring harness
for my 59 and found that the new some of the new metal light bulb fixture's would
stay in place and some would just pop right out even after spreading the split ring
area to try and make them more snug, FWIW, i ended up using a little bit of hot melt glue
around them once they were in place and worked out pretty good.
again FWIW,
Allen
Old 01-08-2016, 07:19 PM   #11
Tod59
Thanks guys!
