Old 01-08-2016, 12:11 AM   #1
Libertys36
1967 to 1969 GM Tilt Column Parts Diagram
Does any of the forum supporters have a detailed diagram of what parts are in the 167 to 1969 GM Tilt columns. I would like to know what parts are suppost to go where, in rebuilding / repairing the column in my truck. It's for an automatic transmission, (350 v/8, with auto), has tilt, has flasher button on lower right side, and does not have the column mounted ignition key. This is an early column, and I believe some parts are missing from previous attempts to fix/repair. I'd like a diagram to go by but can't locate one with good image and parts break down. So, if there is a diagram/image out there and you would like to help a fellow 67/69 Chevy pickup person, much appreciate your assistance. If anyone has a spare "quadrant light and light bulb cover" I would appreciate a spare as one is needed. The Quadrant light is the small glass bulb light that is deep inside the column that is used to light-up the shift indicator bar so that one can tell what gear the column shift is currently in when it's dark inside/outside. (other than moving forward, backwards or just not moving!)
Libertys36 is offline   Reply With Quote
Old 01-08-2016, 01:23 AM   #2
FirstOwner69
FirstOwner69's Avatar
Re: 1967 to 1969 GM Tilt Column Parts Diagram
Welcome aboard the best Chevy/GMC truck forum on the internet.
Here's a good start. http://67-72chevytrucks.com/vboard/s...d.php?t=329008
Regarding the light, maybe forum members KevsClassics or 70shortfleet can help you out. They restore the tilt columns.
You can check the picture below to identify which tilt you have. The middle one is a true truck tilt, the top one is an RV tilt and the bottom one is a van tilt.
FirstOwner69 is offline   Reply With Quote
Old 01-08-2016, 08:21 AM   #3
Libertys36
Smile Re: 1967 to 1969 GM Tilt Column Parts Diagram
Thanks for the information, I believe the column I have is the one on top, I would have to measure the distance from column cone to the neutral safety switch to be sure though. I would like to hear from either of those two if they can help me with the light issue. Thanks for your assistance.
Old 01-08-2016, 08:38 AM   #4
chiefcfd
chiefcfd's Avatar
Here is a pic of the parts. If you have the tilt on the top of the pic you will need to move the location of the NSS as shown here. There are some threads on here that explains this. A service manual has the parts diagram and step by step instructions. It is not easy without the proper tools but it can be done. Just take it slow and methodical.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 01-08-2016, 10:44 AM   #5
too much stuff
Roadtrip!
too much stuff's Avatar
First thing is to positively identify what you have since tilt columns weren't available in trucks from 67-69.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 01-08-2016, 12:08 PM   #6
bronze 72 super
bronze 72 super's Avatar
Also column ignition switches didn't become standard equipment until 1973 on all G.M. light duty trucks. Body change that year also.
1971 Cheyenne Super C-20 402 4 speed
1970 El Camino L-48 350
1999 Chevy Z-71 Extended Cab 4x4
2000 Tahoe Z-71
2004 Monte Carlo S.S. Supercharged Dale Earnhardt Intimidator
1970 Chevelle, Malibu Sport Coupe
2007 Harley-Davidson FLHX Street Glide
bronze 72 super is offline   Reply With Quote
