![]() Join Date: Sep 2013
What the BEST front lowering coils, and shocks...
Looking for the BEST coil for my needs. Engine is getting blown, and that adds 85 or so pounds.
1-I need a GOOD coil that will handle the weight and drive well on the road. I dont mind stiff, just want dependable. 2- At what drop, if any, Do I need to use lowering shocks with a front end drop?
71 LWB Large Bore 6-71 Blown 383 Stroker 4.11 Motive/EOM Eaton Posi Ported/Polished Carrier 15x8/15x16.5 MT Radials B&M Pro Shifter Truck Name- Spike |
Old member
Dennis 2 things to think about.
#1. Helper bags in your coils you have now to stiffen the ride up. #2. Buy shock mounts and use stock shocks. These are the ones I have. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: What the BEST front lowering coils, and shocks...
ECE. Get the big block springs. Try the search button for some of the questions you think may have been asked as there are dozens of threads related to shocks.
I've looked...no solid answers. ECE doesnt sell 3"..thats what I need. any others sell BB 3"
Old member
Here you go since you didn't like the first post.
![]() https://www.performanceonline.com/19...-COIL-SPRINGS/
#6 | |
71 LWB Large Bore 6-71 Blown 383 Stroker 4.11 Motive/EOM Eaton Posi Ported/Polished Carrier 15x8/15x16.5 MT Radials B&M Pro Shifter Truck Name- Spike Last edited by hardwaycooke; 01-08-2016 at 08:23 PM. |
Old member
If you go with the shock relocator doesn't matter about the amount of drop. You use stock shocks.
If you do the helper air bags you want need the new springs.
motor exploder
I've used Belltech nitro drop shocks on my '92 chevy ecsb with a 5/7 drop and really liked them.
I have currently have Chassisworks Varishocks on my '69 along with the shock relocators that Andy suggested above and they are nice as well. I don't know if this is the case on every truck, but I had to 'persuade' my inner fenders a little to get them to fit with those front shock relocators. I'm running a BB with Hotchkis 1500lb/in springs in front and they are pretty firm.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() Use the SEARCH function on this forum - it is your friend!! |
Old member
You know I was messing with you. I still think the helper bags would do the trick though!
hey andy how exactly do the helper bags work?
can i just install them and pump them individually without running lines to a tank? |
#11 | |
Old member
Check the link it shows everything. ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s....php?p=7087437
| Bookmarks |
