SwayBar and traction bar should i use them togeteher
Hello Again maybe you guys can help me. I have a 1978 gmc shorty reg cab just installed calmax traction bars to it should I also install a sway bar or is that not even going to work.
Re: SwayBar and traction bar should i use them togeteher
Are you talking front or rear sway bar? You might get better answers in the high performance section too. I'm interested in this too, I'm installing Caltracs this winter too once I get a few other things done
Rear.
Nope you're good to run both. They do 2 totally different things that don't interfere with one another. Caltracs will limit spring wrap on hard acceleration and move your instant center forward while the sway bar limits body roll in turns.
Pie rule. Everything takes 3.14 times longer than expected to complete -INSIDIOUS '86 |
Thanks.
