Old 01-09-2016, 12:00 AM   #1
cigar-
cigar-'s Avatar
Angry Help with leaves !!!
I am experiencing a problem with leaves falling into and under the cowl in front of the windshield. Eventually they drift down into the kick panel vents and blow into the cab when the vent is opened.
I know I'm missing something that will prevent this from happening. Is there a solution? I am about to buy a used cowl cover and weld small screen onto the bottom to prevent the leaves (and dirt and such) from entering the underside and into the vents. Not sure if that's a good or correct solution. The factory must have had something in place to prevent this.......
cigar- is offline   Reply With Quote
Old 01-09-2016, 12:04 AM   #2
swamp rat
swamp rat's Avatar
Re: Help with leaves !!!
There are some prefab screans avalable, i bought mine some years back, cant recall from who but do a google search. but i have also seen folts use a flexable aluminum screan and a hot glue gun.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-09-2016, 12:06 AM   #3
swamp rat
swamp rat's Avatar
http://www.classicindustries.com/pro...s/ap7236b.html
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-09-2016, 12:09 AM   #4
tommys72
tommys72's Avatar
I used regular window screen and hot glue. Cut the screen to size and glue.
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 01-09-2016, 12:27 AM   #5
DoobieBrother
DoobieBrother's Avatar
We just used some of this.
http://www.homedepot.com/p/Unbranded...LATH/202093395
We bought a sheet, took off the cowl, and cut a piece to fit it. Attached with a few spots of JB Weld. Works perfect and looks good from above once installed.
DoobieBrother is offline   Reply With Quote
Old 01-09-2016, 12:33 AM   #6
FirstOwner69
FirstOwner69's Avatar
These are the screens linked in post 3. They keep stuff out and also hide the view into that ugly pit. No drilling required.
FirstOwner69 is offline   Reply With Quote
Old 01-09-2016, 12:37 AM   #7
DoobieBrother
Looks pretty much like my $7.50 Home Depot solution.
Old 01-09-2016, 12:14 PM   #8
Redline novdog
Redline novdog's Avatar
Here is a another thread that might help.
http://67-72chevytrucks.com/vboard/s...d.php?t=553767
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 01-09-2016, 11:18 PM   #9
El Dorado Jim
I used the ones like FirstOwner69 did, they are stainless steel, I either got them from LMC or( truck and car shops)http://issuu.com/truckandcarshop/docs/ts_60-72_web they are called cowl vent trash guards,they come painted black or in stainless steel
El Dorado Jim is offline   Reply With Quote
