Old 01-09-2016, 01:48 AM   #1
Modest_Man
Am I missing something or am I just an idiot?
I just got a set of the reproduction sport mirrors. The screws will not physically fit into the bracket. They will shear off before screwing in.
Am I just being stupid? I figured these would be an easy "plug and play" thing. Sandwich mirror and bracket around door and screw together.
Was I sent the wrong screws? I know lots of you guys have used these reproduction sport mirrors and I'm wondering if these are the normal screws? I may have to drill out the holes a bit and find someone to weld a nut onto the back of the mounting brackets and pick up some new hardware, which was more work than I was expecting.
Modest_Man is offline   Reply With Quote
Old 01-09-2016, 02:15 AM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Am I missing something or am I just an idiot?
I would just take the backing plate to Home Depot or lowes and get some stainless screws that fit.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 01-09-2016, 06:01 AM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Am I missing something or am I just an idiot?
These go inside the door and you will never see them right. I would get bolts with counter sunk heads and bolt them in. The bolts will stay tighter and never come loose from people bumping into them once installed. Just my opinion though.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-09-2016, 07:36 AM   #4
jdw
I don't see how the counter sunk heads on those screws make any sense in the picture. I'd just go get the right screws.
jdw is offline   Reply With Quote
Old 01-09-2016, 08:20 AM   #5
72farmer
No you are not a idiot.I just installed mine on my 72 and I had the same problem.I kept screwing them in a little and then backed them out.I was very afraid I would shear mine off too.Or jab a hole in my hand with the Phillips head screwdriver.
72farmer is offline   Reply With Quote
Old 01-09-2016, 08:49 AM   #6
Grumpy old man
Grumpy old man's Avatar
Ahhh ! Good old stainless , Run some steel screws thru the bracket to cut the threads before you install them . Stainless seems to be weaker and I've had them twist off many times before .Cutting the threads with steel first helps alleviate this problem and makes any stainless screw install much easier . Or just drill the holes out and hit your local Lowes and buy some 10x24 stainless machine screws and nyloc nuts . the stainless screws at most home stores are flat countersunk phillips head But You can find the phillips oval head stainless at Ace hardware .
Grumpy old man is offline   Reply With Quote
Old 01-09-2016, 09:29 AM   #7
Grumpy old man
I like Mane's truck parts descriptions on the supplied hardware .
http://www.manestruckparts.com/store...Category_ID=17
Old 01-09-2016, 09:52 AM   #8
Kennuck
Kennuck's Avatar
I threaded mine with a tap and then used SS Machine screws.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 01-09-2016, 10:10 AM   #9
joeydurango
joeydurango's Avatar
x2 on having had this issue with these mirrors. I did what Grumpy suggested above and, before installation, ran some steel screws through the backing plate to free up those threads.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 01-09-2016, 10:56 AM   #10
Stainless is known for being soft, And these days, with poor manufacturing by the "new guy" having little quality control, now more than ever you need to chase threads down with a harder material first. The screw size is correct, is supposed to go in snug, and the next size down will be too small, and weaker for holding the mirror even if it did fit. There would also be an issue with size of screw head vs size of countersunk hole in mirror
Old 01-09-2016, 11:13 AM   #11
chiefcfd
chiefcfd's Avatar
Yep x'3. Had the same problem. Did the steel screw trick. The really hard trick is installing it by yourself!
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 01-09-2016, 12:19 PM   #12
REEDS 72
REEDS 72's Avatar
Flip it over and give it a try.
REEDS 72 is offline   Reply With Quote
Old 01-09-2016, 12:27 PM   #13
Modest_Man
Glad I'm not just an idiot. I will definitely go this route and drill the holes out and use nyloc nuts.
Thanks for the tips all.
Old 01-09-2016, 02:31 PM   #14
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
"Throw away the screws..."
That's honesty at it's finest!
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 01-09-2016, 02:57 PM   #15
Grumpy old man
There's not one person who hasn't had this type of problem to deal with at some point in a build /project truck . There are many guys in here who just dealt with these issues 50 years or more ago before computers and web sites with specific year model information available in seconds at your fingertips and web sites full of parts . Try building one of these or any truck/muscle car without all the modern conveniences we have available today just your trusty old tool box the local junkyards a yellow pages book and the kitchen phone hanging on the wall with a 4' cord . No Craigslist, no internet, no battery operated anything ,Just corded drills /gas torches and arc welders . I was lucky enough to grow up around guys like Les Dunham and see his designs in progress before I could drive myself .my father built many of his custom designed car/truck interiors . remember it's only a piece of metal until you drive it down the road ,We all had to learn these small helpful tricks from someone who has dealt with it before . There are no stupid questions .
http://dunhamcoach.com/home.htm
Old 01-09-2016, 03:02 PM   #16
davepl
davepl's Avatar
Random tip of the day that I was reminded of by GOM above: stainless fasteners are NOT anywhere near as strong as steel. If you need shiny and strong, you need chrome plated Grade 8 (or even chrome plated grade 5).
That's for bolts, not screws, but was part of the problem here I think.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-09-2016, 05:01 PM   #17
jdw
I think for the locale stainless will last longer unless it's sealed from the elements, but it's no good for threading. Rust is your enemy here, and you're definitely going to want the screws to strip before some joker grabs your mirror and jacks the sheet metal out of whack. Also, upon closer inspection it appears the holes are countersunk and that backing plate is upside down. Is that true?
Old 01-09-2016, 05:30 PM   #18
GASoline71
GASoline71's Avatar
This ^^^ 99.9% The .1% is held aside... because I do not subscribe to the "no stupid questions" theory.
Back when parts you couldn't find in the brick and mortar shop were ordered over the telephone and sent C.O.D., and you wrote the delivery driver a check. Boy times have changed.
Gary
Old 01-09-2016, 10:19 PM   #19
67ChevyRedneck
67ChevyRedneck's Avatar
Not that it really makes a big difference... But you are screwing them in "backwards".
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-10-2016, 12:53 AM   #20
lovemy71s
lovemy71s's Avatar
same problem for me but like said above. turn plate around and they will go right in. I just did them on my 71 gmc k-10 and had a hell of a time till I asked myself if I was dumb then sat back with a beer and thought about it then boom it came to me, turn the plate around and they go right in.
I love six pack projects
lovemy71s is offline   Reply With Quote
Old 01-10-2016, 01:05 AM   #21
swamp rat
swamp rat's Avatar
Per the wrong screw question, I'm assuming the countersunk heads are a proper fit for the mirror arms? if not then look into that.
Yep you are screwing ther screws in from the back side not the front.
You could check into machine screws as mentioned above, then buy the proper size tap and tap the holes before install.
I agree stainless is weaker.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-10-2016, 01:18 AM   #22
Lattimer
Lattimer's Avatar
It usually inexperience, not stupidity. Stupidity is when you learn the answer, and screw it up again the next time.....
I've learned a ton of little tricks along the way, most of them from working with my dad when he was alive. No shame in not knowing. None of us know everything.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 01-10-2016, 12:40 PM   #23
bronze 72 super
bronze 72 super's Avatar
I just put the original Sport Mirrors back on my '71 the screws go though the mirror and hold the bracket on. This bracket is backwards, lip goes towards the inside of the door.
1971 Cheyenne Super C-20 402 4 speed
1970 El Camino L-48 350
1999 Chevy Z-71 Extended Cab 4x4
2000 Tahoe Z-71
2004 Monte Carlo S.S. Supercharged Dale Earnhardt Intimidator
1970 Chevelle, Malibu Sport Coupe
2007 Harley-Davidson FLHX Street Glide
bronze 72 super is offline   Reply With Quote
Old 01-10-2016, 01:46 PM   #24
Stainless is plenty strong for holding a mirror on. What the steel screw is about is chasing the threads down first to make way for the stainless.
As for the original question, "Am I missing something or am I just an idiot?". Yes, you are missing one good screw to replace the broken one with. I don't know if you're 'just' an idiot or not. Could be coupled with other issues as well...DOH! I guess an IQ test would be about the only real way to know for sure. Never go by the opinions of those not qualified to assess such things. That includes you.
Old 01-10-2016, 02:19 PM   #25
Davidf
SS is plenty strong, but galls easily. Steel or stainless, you should lubricate the treads when first installing screws. Doing so work fine for me when installing mirrors. I used a sacrificial screw to pre-thread holes
Davidf is offline   Reply With Quote
