01-09-2016, 05:38 AM | #1 |
66 Suburban Parts
I just bought a 66 Suburban and would like to know where you order your replacement parts if you need something?
Thank you in advance. |
01-09-2016, 02:28 PM | #2 |
Re: 66 Suburban Parts
Hi and welcome. Ready for some fun?
I am just finishing my project and have some trail and error with suppliers. My first advice is that an original part is best whenever you can get one. Repop parts vary and are generally not built to OE specs despite what is claimed. Be vary wary of replacement body parts. As for suppliers, there are many and many opinions here are mine: LMC is first choice. Even though they don't really do Suburbans, everything cab forward is same as pick up. Their catalog is invaluable. Big inventory, great service, fine prices. Next go to is Classicparts.com. Classic Auto is good too, but Classic Industries not so much. Also not so happy with Brothers. I experienced bad parts and bad service from Tucker. Eckler are good guys. My opinions and experiences only. I have a few sources for used parts. PM me if you want more. Scottie. |
01-09-2016, 08:19 PM | #3 |
Taillight lenses are available through many vendors and they are very good quality and fit. I bought mine back in the 80's at Pioneer Classics in Phoenix
And they are holding up well. I also painted the inside of my housings gloss white, and they are a lot brighter than the anodized aluminum. |
01-09-2016, 08:21 PM | #4 | |
01-10-2016, 04:27 PM | #5 |
in addition to the ones listed by ogsrule
www.truckandcarshop.com is very good and for your rubber products like door seals and window seals, http://www.steelerubber.com/
1960 c30 Apache Panel w/ '95 cummins bt6 turbo diesel (work in progress) NOTE: due to photobucket trying to extort money my photos are temporarily unavailable. currently looking for alternative to fix issue. http://67-72chevytrucks.com/vboard/s...d.php?t=523009 |
01-11-2016, 04:25 AM | #6 |
Thank all of you for your recommendations. I'll check them out!
01-11-2016, 10:23 PM | #7 |
01-18-2016, 10:42 AM | #8 |
Does anyone know where I can order a heaterbox which really heat's the truck?
01-18-2016, 01:32 PM | #9 | |
Never Ending Projects
The biggest problem is, a Suburban is such a large area to heat and cool, no system is going to do a good job as there is just so much area. I know later model burbs actually used front and rear heat and A/C systems. You might need to do something like that. I know there are some stand alone heat boxes that you could plumb and mount in the back behind the rear wheel well area. Between a factory type front and the additional rear, that is likely going to be your best bet.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
