Old 01-09-2016, 10:36 AM   #1
chincha805
need input on this
ok, i have a 86 4.3L V6 , that is carbureted. my plan is to change the stock intake with a Edelbrock 2111 intake , change the 4 barrel stock carberator with a Edelbrock 1404 (500cfm) caburetor, i am removing all the electronics computers and will need tto change the distributor to non computerized MSD . has anyone done this, my goal is to make this V6 run with out any computers.
chincha805 is offline   Reply With Quote
Old 01-09-2016, 10:55 AM   #2
Highsider
Highsider's Avatar
Re: need input on this
I like your thinking.
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 01-09-2016, 03:42 PM   #3
joedoh
joedoh's Avatar
there were a few carbureted 4.3 V6 cars and trucks, try the 84-85 fullsize and same year gbody (monte carlo, malibu, el camino). personally I would buy a new distributor than a 30 year old one, so rockauto or o'reillys should have the parts you need.
and if you have all the harness and computer and the engine runs you are adding a layer of complexity and expense that you dont really need, my advice: install it, get it running, then do your carb and distributor swap. just my opinion though, and my opinion is only worth what it cost.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 01-09-2016, 08:27 PM   #4
chincha805
i guess what i need to know is what kind of distributor would i need to get? my Oriellys and Napa store are clueless on what to do. will a HEI distributor work. i sure it can be done , i know the expense is greater but thats what i want to do.
Old 01-09-2016, 09:47 PM   #5
joedoh
joedoh's Avatar
I just did a quick google search for an HEI distributor for a 4.3 V6 1985 el camino and this came up.
http://www.aipelectronics.com/index....3-8l-4-3l.html
Old 01-09-2016, 10:46 PM   #6
Henry50
Henry50's Avatar
There wasn't a single wire HEI built from the factory for the 4.3,
Here's a little info that might help,
http://blog.wrenchmanrepair.com/2012...ei-conversion/
Henry50 is offline   Reply With Quote
Old 01-09-2016, 11:51 PM   #7
joedoh
joedoh's Avatar
that looks like totally less work than just using the tbi setup that you already have. I'm just being smarmy of course, but looks like good info if thats really what you want to do.
Old 01-09-2016, 11:59 PM   #8
mr48chev
mr48chev's Avatar
O'Reilly's does show a vacuum advance distributor for the 4.3 http://www.oreillyauto.com/site/c/de...2780&ppt=C0334
Evidently the 4.3 came with either a vacuum controlled distributor or a a full computer controlled version in 1985. The compatibility list is the same on the one from OReilly's as the one Joedoh showed if you are inclined to go junk yard hunting.
My ongoing truck projects:
Old 01-10-2016, 08:21 PM   #9
chincha805
i'm going to buy a new one. thanks for the info.
