Door weatherstrip
I'm just installing the door weatherstrip, and didn't know if there was supposed to be some sort of cap covering the end at the box? I guess if the hard top was on you wouldn't see it, but with a soft top it looks unfinished.
![]() Join Date: May 2011
Re: Door weatherstrip
I think I saw a cap for that in the LMC catalog.
I think it is a plug type thing.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
I'll check with Bill's trucks in the morning. I never think of checking LMC because it's just too expensive for us north of the border especially now that an item that costs $1.00 US will now cost us $1.42 because of the exchange rate, and then we have to add shipping, brokerage, taxes... I'm too old now, but if I had to do it over again I would have moved to the States when I was young.
![]() Join Date: May 2006
JMO, but if you plug it, where will the air go when you collapse the weatherstrip. Could make it hard to close the door
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
Bill's truck is awesome I bought my sliding hard top windows from him for 80 dollars US.
that's just it, I've never seen it. But, a cover would work. When the door is closed doesn't it pinch it shut, dunno
The Chevy parts catalog shows a plug there (page 17-6). It must have been made of a softer material than the plugs sold by LMC. The LMC plugs that I tried are too hard and usually pop out when the door is closed.
72 Ochre Blazer 69 Camaro Z28 Garnet Red 48 Willys (rolled) |
#13 |
They weren't glued in from the factory, at least mine weren't. Kind of wish the were so I wouldn't have lost one by blowing it out with the pressure washer.
This is my remaining one.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#14 |
I just picked some up today. I'll glue them in but all the way around to let air escape. I'll post a pic once installed. Thanks for the replies !!
#15 |
What is the material of your plugs?. My LMC plugs are made of hard rubber, definitely not like the originals shown above. When inserted without some sort of cement they literally launch 15 feet across the garage (LOL ) when the door is closed. When glued in they inhibit the closing of the door..... curious to see what yours do.
#16 |
The way ls1novas is designed makes sense, if you glued the tab in, it would still vent the pressure out the curled up edges
Never saw them before, great info.
#17 |
Here's mine installed. I only glued a small portion of it so that I could remove them if they don't work out. They are made of hard rubber, and I think they will interfere with the door. I'll know better once I get the doors painted and installed. The ones posted in LS1's post look like they are a softer material and would work better.
Too bad the ear plugs I have here are bright orange !! LOL |
#18 |
I have attempted to use the hard rubber plugs as well. Glued them in and they just get squeezed out over and over. I really like the idea of using an ear plug! Color it black with a sharpie and bingo. It should be soft enough to compress when the door closes without wanting to launch itself. The back side of those orange ear plugs also have a nice finished surface that would look perfect.
| Bookmarks |
