Old 01-10-2016, 02:07 AM   #1
Farm Shop
Farm Shop's Avatar
32 spline NP208 is not mating up to NV4500... what am I doing wrong??
I could really use some insight as to what I am doing wrong here. I did a TON of reading on here, pirate4x4, etc, and thought I had all my ducks in a row, but apparently not.
I'm swapping out the SM465/NP205 in my brother's '72 K20 for an NV4500 from a 1996 GMC 1 ton. I got a 32 spline NP208 transfer case since everything I read said it would bolt right up to the NV. Long story short, it doesn't.
Please excuse the nastiness, I was just trying to verify fitment of everything before cleaning and painting.
Output shaft of NV4500
NP208
When I install the TC to the trans, this is all the further it will slide into place
After some measuring and head scratching, I put blue marker on the aluminum casting of the 208 and verified that the portion of the input shaft bearing support contacts the large damper on the output shaft, keeping it from fully seating. You can see where the marker is rubbed off due to contacting the damper in the trans.
Where did I go wrong? Thanks in advance for any help or recommendations on where to go from here.
-kyle
1970 SWB 2wd C10, Vortec 454/80e, CPP 3/5, slotted mags, patina
1972 K20 Super Cheyenne, Short bed, EFI 396, NV4500, NP208
1970 GTO Judge, heads/cam LS1 & stalled 4L60e
Farm Shop is offline   Reply With Quote
Old 01-10-2016, 11:19 AM   #2
b454rat
Re: 32 spline NP208 is not mating up to NV4500... what am I doing wrong??
Looks like you need a small spacer.
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 01-10-2016, 01:02 PM   #3
kwmech
http://www.advanceadapters.com/tech-...modifications/
The damper was meant more for the diesel applications
Old 01-10-2016, 01:47 PM   #4
snj8198
snj8198's Avatar
ya, two piece design fly wheels. From what I understand, the two piece design created enough harmonics that, without the tail balancer, would vibrate and destroy the mainshaft. I have a buddy with a '95 6.5L Diesel this happened to twice. Expensive learning lesson.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 01-10-2016, 05:00 PM   #5
franken
The AA conversion guide and other sources mention cutting the 4500 output shaft. You could also make a spacer from aluminum using a gasket as a template. Make sure all the bolt holes line up.
franken is online now   Reply With Quote
Old 01-10-2016, 09:04 PM   #6
kwmech
You shouldn't have to cut the shaft if the damper is removed. And change the input seal on the 208, looks like it has cracks in it
Old 01-11-2016, 08:56 AM   #7
Ah yes, the DMF (dual mass flywheel) folly. I figure DMF better describes who's idea these were. Had the snubbers go out on one and another cracked almost all the way around the center. GM didn't even supply replacement DMFs. Instead, they offered a conversion to tried and true solid flywheel, which made for an involved and expensive conversion. Really sucks when it happens after you install a fresh GM crate NV4500 and Centerforce dual friction made for the DMF. Had to get another clutch and break into my new transmission. Not to mention dropping all that out of the truck again.
Old 01-11-2016, 09:47 AM   #8
Farm Shop
Farm Shop's Avatar
I'll have to look into removing the damper, I guess. I'm just really surprised to run into this after everything I read about the 208 and early 241 being a bolt-on part for the NV4500. This trans was behind a 350 in a 1 ton dually.
And good eye on the seal. It will be replaced along with several others after the parts are cleaned and painted.
Old 01-11-2016, 01:38 PM   #9
Farm Shop
Farm Shop's Avatar
So after some more digging, it seems like this trans is a bit of an odd duck. The damper (big steel drum counterweight) apparently started in 1995 behind the 6.5 diesel to fix the 5th gear nut loosening issue associated with the hammering harmonics of a lugging diesel. The weird thing is that this truck has a vortec 350... but it was a 1 ton dually, so maybe all 1 tons got the same trans?
I don't know. Regardless, the damper has to come off. Behind a mild big block that won't ever tow much to be a problem, eliminating it shouldn't be an issue. Now I just need to find a trans shop with the correct spanner/socket to do it for me... spending $170 on a production socket is not a great option right now!
Old 01-11-2016, 02:05 PM   #10
snj8198
snj8198's Avatar
Dang, I just read an article somewhere that you can drill a hole through on each side of the nut and just chisel it in half saving the cost of that expensive spanner socket. Most replace that nut anyway. I'll dig a bit
Steve
Old 01-11-2016, 04:51 PM   #11
CrewCab59
CrewCab59's Avatar
The nut is the same as a Dana 44 spindle nut socket, I have one that I made long for the shaft .
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 01-11-2016, 05:23 PM   #12
Farm Shop
Farm Shop's Avatar
That is great information! Thanks!!
Old 01-11-2016, 07:30 PM   #13
CrewCab59
CrewCab59's Avatar
A socket will be needed any ways to reinstall so get a spindle nut socket cut it in half and weld a section in. That way you can still use it on the hubs and Trans.
Just a thought.
1971 Chevy C/10
