Old 09-19-2003, 10:14 PM   #1
rage'nrat638
rage'nrat638's Avatar
Question Need Some Help On Engine Codes...please
BACK OF BLOCK........3970010
FRONT OF BLOCK.......14R491193
looked at mcnasty's and found it's a 350 but not much else
any idea's thanks mark
rage'nrat638 is offline   Reply With Quote
Old 09-19-2003, 10:25 PM   #2
RShaips
Try this site. www.mortec.com .Has lots of good info.
RShaips is offline   Reply With Quote
Old 09-19-2003, 10:27 PM   #3
68 Stepside
huh?
68 Stepside's Avatar
there should be another number on the front of the block. I think the number you have is a partial vin. In the attached pic, the VO112CLJ is the number you're looking for. It won't be the same of course, but the number/letter grouping should look like that.
Good luck, keep us posted.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 09-20-2003, 12:44 AM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
If I remember correctly it would be a 4-bolt main 350 truck motor.. I think my new crate motor had the same # on it but would have to go look..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-20-2003, 12:59 AM   #5
J.Lance
Too many is never enough!
date code
Definitely a 350, look at the "clock" and date code on the back of the block and post if you can. The most usefull will be the last three letters on the pad you see in 68 Stepside's pic above. Get those letters and a date code we can tell you what application you've got.
Jason
Jason
1968 K10 SWB Fleetside
1971 K2500 GMC LWB
1968 K20 (later frame, donor body)
1972 C20 LWB parts truck
1993 K2500 Suburban, tow rig, 454, 4L80E
NEW!! 18' Siem's car hauler
2004 Honda Odyssey (family man!)
J.Lance is offline   Reply With Quote
Old 09-20-2003, 03:18 PM   #6
rage'nrat638
OK GOT THE OTHER NUMBERS...
V0626CMR.......LET ME KNOW......PLEASE
F224
Old 09-20-2003, 03:40 PM   #7
bigjimzlll
bigjimzlll's Avatar
1974 CMR 350 tur hydro trans. - 145 2 A
1978 CMR 350 m/t L82 4 220 4 Vette/Z-28
1980 CMR 305 auto trans. H LG4 155 4 full size
http://www.nastyz28.com/spmenu.html
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 09-20-2003, 03:51 PM   #8
68 Suburban
68 Suburban's Avatar
Mark, what are your plans for that motor?
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 09-20-2003, 03:53 PM   #9
rage'nrat638
WELL MY BUDDY'S GOT THIS ONE.....
want to look at the one in the truck to see if it can be used or not???
if not will have to use this one after a rebuild of course
Old 09-20-2003, 03:57 PM   #10
rage'nrat638
so jim a 74 block
and it does have a turbo 350
4 b.carb
is it 4 bolt or 2 bolt??
Old 09-20-2003, 04:37 PM   #11
bigjimzlll
bigjimzlll's Avatar
it could be either....no way to tell until you pull the pan..the 010 blocks have more 4 bolts than 2 bolts...having said that..I have had 3 010 blocks..all three were 2 bolts...go figure
Anderson,CA
Old 09-20-2003, 05:05 PM   #12
miket
miket's Avatar
Here is what Mortec says according to the first batch of numbers:
3970010....302.....69....4 bolt...Z-28 Camaro
3970010....327.....69....2 bolt...Trucks and industrial
3970010....350...69-80...2 or 4 bolt
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 09-20-2003, 10:38 PM   #13
rage'nrat638
thanks for the help guys ...i needed it....
hopefully it's a 350 w 375 h.p. 4 bolt
Old 09-20-2003, 11:09 PM   #14
miket
miket's Avatar
Mark,
whats this in?
Old 09-20-2003, 11:18 PM   #15
rage'nrat638
nothing...its just sitting in a corner in my buddy's pole building
w/350 turbo trans
Old 09-20-2003, 11:24 PM   #16
miket
miket's Avatar
Okay.....just curious.
