Old 01-10-2016, 09:08 PM   #1
carkivey3
hei distributor for 67 c10 w/327
giving my son a hand getting his grandpas 1967 c10 back on the road. i remember my early years replacing and adjusting points and would rather have an hei. i can find a lot of info on converting the old distributor to a hei and some info on which ones to use from a junkyard. the latter is what we are interested in. can anyone give specific info on what years to use such as any 350 from 74-78. does it have to be small block specific. will any gm vehicle from certain years work. thanks for info
carkivey3 is offline   Reply With Quote
Old 01-10-2016, 09:20 PM   #2
Mike C
Mike C's Avatar
Re: hei distributor for 67 c10 w/327
Must be from a small block or big block Chevy. You can use any from 75-85 pretty much, just get the 4 pin module. I would recommend just buying a new aftermarket one. They are available for less than $100 with cap, rotor, coil, and module. Just add a wiring harness. I use the terminal marked IGN in the fuse box and just plug in a 10 ga wire.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-10-2016, 09:20 PM   #3
hugger6933
Welcome to you from eastern parts of Arkansas.Now any small or big block Chevy motored vehicle will have the right HEI. Your looking about the right range in the early 80's they put a what I call a 4 pin HEI in and it had some timing deal [ESC] they could work if you hook the black and white wires together on the module but why not look to a Skip White. i know a lot of people here run them but still a lot of people talk bad about them but for the most part the reviews are pretty good. You can buy one with cap rotor and coil from E-bay for less than $70 or so bucks. that in my book beats looking for one and then bring it in just to find you have to buy a coil or module or something like that that will end up more in the long run.
Now I have heard of those who weren't happy replace the Skip White module with a good Delco and that made them happy with the dist. I have thought about putting one in my C60 [1965] with a 292 that i plan on using to haul scrap from my shop with.
hugger6933 is offline   Reply With Quote
Old 01-10-2016, 09:21 PM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
Chevy V8 distributors are the same BBC/SBC. You want an early style HEI with the 4 leads to the module. Order one for the same type of C/10 but as a "1975", and you'll be good.
I've found that a new HEI is better [and cheaper] than replacing all the components from a junkyard Delco-Remy HEI.
Do not use the old resistor wire to the points coil (+). You need to run a fresh wire 10 or 12 Ga. from Ign Unfused to the HEI B+ terminal. That way you get a full 12 VDC at all times. The OEM resistance line 16 Or/White/ppl will pass 12 volts initially then as it warms up, increases resistance, dropping voltage to 7- 9 VDC. Bad for HEI coil, but good for not burning up points.
Old 01-10-2016, 10:09 PM   #5
budnikguy
budnikguy's Avatar
Following
budnikguy is offline   Reply With Quote
Old 01-11-2016, 01:02 AM   #6
jeffahart
jeffahart's Avatar
You can get a Skip White Ready to run HEI unit. I think $39, I use one. I spent twice as much on wires as the distributor. It burns all the gas and has given no problems. Spend your money on wires. Get a hot coil. You will burn gas.
White K20
jeffahart is offline   Reply With Quote
Old 01-11-2016, 01:10 AM   #7
zeldman
zeldman's Avatar
If you buy a new HEI unit, be sure to go to the local GM dealership and buy a module made in the USA. The new units will come with one made in China and it will just quit working.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
Old 01-11-2016, 09:15 AM   #8
Supergas
Supergas's Avatar
Lightbulb Re: hei distributor for 67 c10 w/327
If you want to spend a few more bucks but have ZERO issues, use a DUI HEI. They have a lot of options for all vehicles..
http://performancedistributors.com/p...-distributors/
Stands for Davis Unified Ignition and it is a bit pricey, but works perfectly.
Another option is CRT, they offer an HEI for our engines for a lot less than DUI.
http://www.crtperformance.com/crt/di...or-detail.html
Most of the ebay cheap ones are chink and not worth using in my book..
I have only used the DUI in the past and never had a problem, but I may try the CRT as it has very good reviews on another board..
Good luck,
SG
Gene
2021 Chevy Silverado CC Custom (DD)
2018 Tahoe LS
1964 Oldsmobile F85 Post
Supergas is offline   Reply With Quote
Old 01-11-2016, 07:43 PM   #9
Redline novdog
Redline novdog's Avatar
Make sure you have 12 volts running it!!!!
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 01-11-2016, 09:07 PM   #10
davepl
davepl's Avatar
Meh, until you don't. I don't know who Skip White is but the discount HEIs I've seen are garbage. I've thrown more away than I can count.
Meanwhile, the factory unit out of a '75 Monte Carlo still runs strong with the original module, I pressure wash the engine, it doesn't care.
It seems there is a HUGE difference between GM and knock-off. But I'm not speaking of any particular brand (just a whole country - China).
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-11-2016, 10:47 PM   #11
jeffahart
jeffahart's Avatar
Basically, I refused to get shamed into not getting a skip white. What's the point for me to put bucks into a tired 100k+ 350. I've been running it for over two years with no trouble. Quite a few others are running them as well. They are a no brainer drop in with a hotter coil.
Don't get talked into a setup that you don't need. Best is not always the best choice. Keep that in mind as you delve into the world of fixing up a money sump.
Get a decent ignition when the time is appropriate.
White K20
Old 01-17-2016, 09:12 PM   #12
carkivey3
just got in a skip white 8500r. will install this week if it warms up
Old 01-17-2016, 09:49 PM   #13
davepl
davepl's Avatar
I don't save money on ladders, Lasik, distributors, pitman arms, and anything else that has a single point of failure.
Your tired 350 still has seven more cylinders if one quits, but if you want it to get you home, there are certain parts that MUST work near-perfectly, and ignition is one of those.
Hope it works out. It'd be nice if there were indeed a reliable source of cheap HEI units, I just know I've never seen one. But then I've never had a SW, whatever it is.
Old 01-17-2016, 10:19 PM   #14
jeffahart
jeffahart's Avatar
See what I mean?
NO... buying a distributor or ignition components are not life altering decisions. Hey why stop at ladders and eye surgery, why not make it as important as pacemaker implants.
Yes, it's an inexpensive component... but hey, I've seen expensive components fail too. I was not born yesterday; been using aftermarket parts for years.
Too funny. HEI same as Ladder or Lasik eye surgery... funny!
carkivey3: Odds are your new distributor will work out fine, and work for years. I'm a big fan of spending money on good wires for throughput.
Hey watch out for those single points of failure.
White K20
