Old 01-10-2016, 09:14 PM   #1
92Cheyenne
transmission issue
My 92 Chevrolet Cheyenne 1500/5.7 is shifting through all the gears before hitting 35 mph. If I get in it a little bit it shifts fine. Any suggestions?
92Cheyenne is offline   Reply With Quote
Old 01-11-2016, 07:16 PM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: transmission issue
Bad vacuum module maybe? Not sure your tranny has one. Is it a 4L60?
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 01-11-2016, 11:37 PM   #3
GM-power
GM-power's Avatar
Probably has a 700r. Sounds like the tv cable needs to be adjusted. Does it go into overdrive by 35?
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 01-12-2016, 07:41 AM   #4
92Cheyenne
Yes it goes into overdrive at 35 mph also. i wasn't having any problems it just started about a week ago. i swapped out the TPS thinking that could have been it, but I was wrong.
Old 01-12-2016, 07:26 PM   #5
61_FL_Apache
Who Me?
If its a TV cable issue, make sure its adjusted just right.. You can trash your tranny if its not adjusted right.
Steve
2001 Blazer 4D 2WD
Old 01-12-2016, 07:52 PM   #6
mountie
mountie's Avatar
It should hit 2nd gear in the middle of the intersection ( when light turns green).. Boy,.... nearly impossible to explain how to reach behind the cable bracket on intake manifold, "click" the lock loose, slide the cable jacket - to adjust cable... ( mounted on bracket)...
The cable sets the transmission pressure. ....Too low, and the transmission pressure is set to 30MPH, when you are driving 60MPH... You can overheat it.
A good transmission shop should be able to adjust the TV cable in a minute .
Again, at "normal throttle", second will shift in middle of street, on acceleration from a stop sign.
'70 GTO Midnight Blue
'88 GMC Sierra SLE 392,000 miles-(2018) sold to Classic car shop in Germany.
'93 Cadillac STS Black
'93 Mercedes SL 500 Teal
'86 Yamaha FZ750 - 15,000 RPM
'86 Yamaha FJ1200 - Criminally Fast
2016 Ferrari 488 GTB, I drive it - don't own it.
'05 GMC Yukon XL , SLT 4wd ( just purchased 2018)
mountie is offline   Reply With Quote
Old 01-13-2016, 08:06 AM   #7
92Cheyenne
I watched a few videos on how to adjust the TV cable, gonna give it a try and if I can't get it I will take to a Trans shop and get it adjusted. I appreciate yall's help and i will keep you posted.
Old 01-16-2016, 10:28 AM   #8
92Cheyenne
inside the tranny where the tv cable is the pin that is pushed in when accelerator is pushed, should it be tight?
Old 01-19-2016, 01:55 AM   #9
WestButteTruck
Kung Fu Master
WestButteTruck's Avatar
Check out this article it may help.
http://www.tvmadeez.com/article/
72 GMC SuperCustom 4x4
1972 Chevrolet Cheyenne Super 4x4
WestButteTruck is offline   Reply With Quote
Old 01-19-2016, 09:54 AM   #10
92Cheyenne
i have a new plunger and sleeve on order hopefully this will help.
